Strip Table in Oak and Walnut
Intro: Strip Table in Oak and Walnut
However I needed to make something that would not look out of place againts the rest of the furniture in my house.
The timber is shop bought (about £120) of oak and black walnut.
I apologise now for the lack of photos of the construction but I have attached a detailed sketchup model and plans for each component.
Have fun and hopefully someone with better carpentry skills than me can do it justice.
STEP 1: Understand the Design
http://sketchup.google.com/intl/en/download/gsuviewer.html
and open the file in it. Spin the model round to get a good look at it.
The basis for each component is a 25mm x 30mm section. The real change I made to the design during construction was to cut down the number of threaded rods to 3, however I think in hind sight with a decent set of sash clamps they could be omitted altogether and the top could be just glued.
STEP 2: Select Your Wood
I think it would work with scrap wood or even thick ply as long as you have the right equipment to regularise it.
For example 22mm ply cut into 30mm strips would probably give a great surface effect to the finished table.
STEP 3: Start Choppin'
Always liked a bit of Dinosaur Jnr. , Sorry.
The most time consuming part is cutting the tenons for the legs I used a band saw which wasnt the sharpest and therefore a lot of filing and fitting and filing... etc was required in order to make up the compnents for the 4 legs.
Each leg requires
3x component 1
2x component 2
2x component 3
1x component 3A
2x component 4
1x component 4A
The other change I made was not to cut a tenon into components 3,4 (which have become 3A and 4A) and 6. instead I cut the centre pieces flush to what would have been the bottom of the tenon, I have amended this in the sketchup model and noted it on the component pdf.
use table components.pdf
STEP 4: Continue Choppin'
2 x component 5
2 x component 6 (see amendment on the pdf)
33 x component 7
I used only 3 threaded bars in the end one in the centre and one over each of the legs..
If you use 10mm threaded bar use a 12 mm drill bit, this will give you a enough tolerance to push the rods through the 37 sections that make up the table top.
STEP 5: Assemble the Legs
STEP 6: Assemble the Top
Dry fit the parts first, make sure you can fit the threaded bars through all the pieces and they can be pulled together by tightening the nuts. Do this without the 40mm end strips (component 5)
Once you are happy the table top fits together and stays flat take it all apart again.
STEP 7: Sash the Top
Thread all the top section back on to the threaded bars this time glueing each one in place.
When all the sections are on except the 40mm end strips put the washers and nuts on the other end and tighten the strips together.
STEP 8: Trim the Threaded Bar
You need to trim the threads to 15mm + the thickness of the nuts you are using. This means that you can then fill the holes with a plug when you are finishing. I havent filled the holes yet as I quite like how they look. on the finished table.
Leave the nuts on when cutting the thread as it will help to straighten out the thread when you remove them. If you cut the thread without the nut on it will be really difficult to re fit the nut afterwards.
STEP 9: Fit the End Strips
Again dry fit them before gluing.
STEP 10: Finishing
There were a couple of strips which had ended up a few mm lower than the others so I glued in some strips of scrap oak to fill in the difference then sanded these back flush.
Dont forget to sand the legs.
Finish with a hard wax oil this wont change the colour too much and will protect the surface.
STEP 11: Fit the Legs
Glue and screw to fix in place. use 50mm screws and counter sink them first.
If any one trys this please post some images!
10 Comments
craftyv 13 years ago
glorybe 13 years ago
hogthrob 13 years ago
I spent quite a long time redesigning the table with a folding plane. Originally the top surface was going to fold down into the legs but these were a compromise to get the folding style but with the amenity of being able to sit round the table. without the legs getting in the way.
CementTruck 13 years ago
It looks like the threaded rod is the only lateral support as I don't see any stringers that go across the bottom of the table for lateral stiffness. Does the table bow (forward to back) when a load is placed on the center?
I was planning on making a butcher block tabletop this way, but was planning on using kitchen cabinets as the base, which would control the bowing.
Kudos on a great build! I really like the minimalist design. I'm also a fan of using different woods in a project.
I think the difference with a butchers block top is that the timber is sashed up so the end grain becomes the surface I would think that the kitchen units would be very supportive bu also you could strap the sides with timbers running latterally so you end up with a great big stringer.
Are you making an island unit?
Thanks for your comments.
aeray 13 years ago
Dr. Pepper 13 years ago
wholman 13 years ago
