Introduction: Stuffed Skull
This is a great project for someone who is just started to make stuffed crafts, it is a very cheap and accessible project in which you can easily use recycled materials.
Supplies you are going to need:
two sheets of cloth or felt of one color
one sheet of cloth or felt of another color
needle and thread Scissors Stuffing glue (optional)
Step 1: Cut
Step 1: Twice cut your base cloth or felt sheet into an around 5-6 inch oval.
Then cut a slightly smaller oval out of your top layer sheet
Step 2: Sew
Step 2: Sew the layer you want on the top to the bottom layer.
Step 3: Cut and Lay Out Your Face
Step 3: Cut the various shapes you would like for your skull, I went with a dia de Los Muertos inspired skull
Next, if you would like, glue those pieces to your top layer. After that use your needle and thread and sew the pieces onto the top layer.
Step 4: Fill and Sew
Step 4: Finally, sew your facepiece oval and the second base oval together, leaving a small opening at the top. Then fill with your stuffing and close the hole.
You're done!
