Introduction: Stuffing of Rock Hand
Choose a fabric for the body of Rock Hand
Making your own patterns, this is where it really gets fun! This is where you can create something truly unique and personal and it doesn’t necessarily have to be that hard.
The 2D pattern is basically a flat design, that is, until it gets stuffed.
set the pattern aside. then cut along the lines with scissor.
Practice and practice!
Step 1: Supplies
pencil
parchment paper
scissor
fabric
fiberfil or cotton balls
sewing thread
sewing needle
Step 2: Cut Out the Outlines
TO MAKE A PATTER, hold or tape parchment paper over the template and trace around the edge with a pencil.
Lay the pattern on the minky or other soft fabric and cut it out "PRETTY SIMPLE"
Transfer pattern and cut shapes out of gray.
Step 3: Sew Both Sides Together
Pin and sew together your two body outlines together if you necessary.
basting stitch
Arrange shapes as in the photograph. sew in place using a straight stitch.
thread embroidery needle with embroidery thread. use a white stitch to create a mouth.
Step 4: Turn Them Inside Out
Align back piece with front. use a blanket stitch around the outside edges to sew the front and back together.
Pull it through the opening you left open, if it was stuck inside piece, turn them inside out use a scissor to put inside out.
Take your stuffing and feed it through the gap you've left in your stitching. You'll want to pack it in until the doll holds its shape well, but you can adjust fullness to your liking until the animal is as firm as you want.
Step 5: Finish and Cuddle
Tuck fabric inside the gap to reinforce the seam. Take one side of the fabric and push it through the gap in your stitching. Then sew the gap shut, being sure you stitch the tucked as well to make a strong seam.
Felt is super easy to hand stitch with, so if you don’t have a sewing machine.
if you think that's too easy! Prove it!
