Introduction: Stylish Copper Bracelet for Men
Friends this is the second type of bracelet i have done and am gonna show you how to make it.
Everyone knows copper has capacity to absorb positive vibrations. hence i took copper for making jewels
I took the copper wire from my waste Computer UPS transformer. and you can get it from any hardware shops.
Am gonna use all the supplies which is available in our home so that any one can make it.
Step 1: Items Needed
Very simple and basic items to make sure every one can able to do this on their Own.
1, Copper wire
2, Cutting pliers, nose pliers
3, Lemon
4, Steel rod
Step 2: Making Copper Rings
1,with the use of Steel rod wrap the copper wire around the rod as shown in the image.
copper is flexible material we can just wrap the copper wire in rod by our hand.
2, Once you have wrapped the copper wire in rod as per your requirement you can now remove the copper coil from the rod as shown in figure 2.
3, With the Help of Cutting Pliers Just cut the Copper coils which look like Rings as shown in image 5.
Make sure that you cut the coil in such a way that,each small ring looks like a circle.
Step 3: Join the Copper Rings
1, In the above image you can see how i have opened and closed the Copper rings and this is the main process of making the bracelet.
2, with the help of nose pliers hold the two end point of copper ring and just slowly bend and adjust to make sure both end points of ring is straight and there should not be gaps between the ring.
3,First pick a open copper ring with help of pliers and insert a 2 closed rings inside it and close the Ring with the help of pliers as shown in above image.
Step 4: Continue Attaching Copper Rings
1, Attach the copper rings as shown in the Image 1 follow the images and attach it and this is the simple weaving that anyone can do. make sure it looks like above figure.
2, Once you have weaved the required size of bracelet take another 2.5 m of copper wire and bend that wire with help of nose pliers to look like S as shown in above images.
3, once you made the Hook just attached the Hook with the one end of the bracelet. as shown in image 9.
Step 5: Apply Lime Juice and Its Ready to Wear the Shiny Bracelet
Apply 1 spoon of Lime Juice or Vinegar to make the copper more shiny.
This is the Final look of the Bracelet when its in hands.
when you wear this am damn sure that every one is going to look you and asks you about the bracelet.
Try this in your home, i hope every one likes it.
Thank you Friends.
