Introduction: Stylish Pen Knife of Upcycled Bamboo
Hello again! This is a short Instructable on how to to make a stylish pen knife for your work place. It takes about 5-6 hours (not counting drying time for glue). Fairly easy -the do or die part is the final sanding and polishing .
Material needed: thin pieces of bamboo, small pieces of black or red plastic( preferrably Micarta or other plastic suitable for glueing and sanding), wood glue, drum sander, band saw. And a nice knife blade with a long thin shaft.
Knifes and tools are sharp. Be careful if you are not used to handlig sharp tools. put a few layers of tape on the knife blade while working. This will protect your fingers somewhat. And the blade from unwanted sanding marks.
I hope you enjoy! All comments/ suggestions/questions welcome! /Frederik
Step 1: Glueing Bamboo
Glue together thin pieces of Bamboo as you see in picture. Wood glue works fine.
Step 2: Sawing
Saw the glued bamboo into pieces matching the size of the knife handles height and width ( not lenght). Sneak a peak at next step, which clarifies what I mean. Hopefully.
Also saw pieces of plastic (or possibly metal) for the end pieces of the handle.
Step 3: Drilling
Drill holes in all pieces to allow them to fit on the knife shaft. See photo how to find middle.
Step 4: More Glueing! (OMG!)
Now glue the subsections together on the knife's shaft. Sort of like collecting berries on straw. An analogy which probably means nothing to younger generations... Berries? Straw!? What is he talking about!
Step 5: Sawing and Sanding!
Saw/sand your knife handle to the shape you prefer. A band saw and a drum roll sander are useful here. You can also do it by using only files or even a carpenters knife. But it will take you looonger....
Step 6: Fine Sanding, Polishing and Oiling
Spend time finely sanding the handle. Start with 150 grit and gradually switch to finer papers( 250, 400, 600 and 1000). No cheating!
Put some oil or varnish on it! Watch the colours appear!
Step 7: Optional Knife Stand
By using a block of wood you can make a fancy desk stand for your knife!
