Introduction: Stylish Upcycled Tyre Tea Table – a Creative DIY πŸ›žβœ¨
About: FUN DIY, CRAFTS, EXPERIENCE THE JOY OF DOING IT YOURSELF. OFFICIAL CHANNEL.
Why throw away old tyres when you can turn them into a stunning piece of furniture? This DIY project transforms a discarded tyre into an elegant and functional tea table. With a blend of creativity and sustainability, this upcycled table not only enhances your space but also promotes eco-friendly living. Let’s dive into the step-by-step process of making this unique tea table.
  1. Scale
  2. Pencil
  3. Cutter
  4. Old tyre
  5. Plywood (for top and the legs)
  6. Jute rope (for wrapping)
  7. Acrylic Sheet
  8. Strong adhesive or glue gun
  9. Epoxy
  10. Succulants
Step 1: Binding the Ropes
  1. Place the three jute ropes side by side.
  2. Start twisting the ropes around each other tightly.
Step 2: Creating the Top
  1. Use a jigsaw to cut a round plywood piece to fit your table top.
  2. Sand the edges with sandpaper for a clean, finished look.
  3. Drill small holes around the edges for screws.
  4. Secure it to the structure using screws.
Step 3: Wrapping Tyre With Jute Rope
  1. Use a hot glue gun or a strong adhesive to fix the starting point of the jute rope on the tire.
  2. Ensure each strand is placed closely to the previous one without gaps for a smooth and uniform look.
  3. After applying glue, press the rope against the tire for a few seconds to ensure it sticks well
  4. Once you reach the last section, tuck the rope neatly and secure it with extra glue to prevent fraying.
Step 4: Fixing the Legs
  1. Draw the desired shape of the legs on paper.
  2. Transfer the drawing onto a plywood or MDF board.
  3. Use a jigsaw or a scroll saw to carefully cut out the shapes.
  4. Sand the edges for a smooth finish.
  5. Mark the leg positions on the wooden board that sits on the tire.
  6. Use screws or nails to reinforce the connection.
Step 5: Making It Top Shelf
  1. Use a sturdy circular Styrofoam sheet to create the mold.
  2. Cut a circular styrofoam sheet of the desired hollow size.
  3. Secure it in the center.
  4. Then Pour Concrete mixture around it and let it dry
  5. Once dry, carefully lift or twist the styrofoam sheet out.
  6. Unmold the entire structure gently.
  7. And The Tabletop is ready
Step 6: A Layer of Epoxy
  1. Slowly pour the epoxy over the surface.
  2. Use a spreader or brush to even it out.
  3. This will give a smooth, glossy finish.
Step 7: Fill Up With Greeneries
  1. Take a bowl and paint it.
  2. Place it in the centre hollow space.
  3. Go for low-maintenance, small plants like succulents, moss, or air plants.
  4. Add a layer of pebbles for texture.
  5. Put a layer of acrylic sheet over the greeneries to cover the area.
  6. Mist them occasionally and trim them to avoid overgrowth.
Step 8: Enjoy Your Tea
Your stylish, eco-friendly tea table from a recycled tyre is now ready! This project is an excellent way to upcycle waste materials, reduce environmental impact, and create a one-of-a-kind furniture piece for your home. Whether placed indoors or on a patio, this DIY tea table is sure to be a conversation starter.
