Introduction: Suicide Adapter
- DISCLAMER -
IF YOU'RE SUICIDAL DON'T READ ANY FUTHER GET OF YOUR ASS AND FIND PROFESSIONAL HELP-
A Suicide Adapter...Why...?
Because people suck at killing them self
so this is for all you emo's out there
An adaptor to make you fingers fit the power sockets.
Stop cutting your wrists without results.
Do it proper use the Suicide Adapter!
QUIT JUMPING IN FRONT OF TRAINS !
Step 1: Equipment
To make the suicide adapter you need:
-an old plug
-2 packs of Fimo Clay
-A screwdriver/hamer
-Aluminum foil
-an oven
-an old plug
-Aluminum foil
-an oven
Step 2: Work It Bebe!
Wash you hands because dirt shows on the clay.
Open the clay and work it until it gets soft enough to shape.
At first the clay is pretty hard so this can take a while. Don't use water.
Step 3: Electrode Are Nice
Detach the metal pins from the plug.
Open it and take out the pins.
Or take the hammer, smash the plug to pieces and start searching for the pins.
Step 4: Contact
Then shape it around your fingers and create a nice shape as you wish.
When your done, take the pins and stick them trough the clay while making sure that
you fingers make contact with the metal.
Step 5: Half Baked
Put the adaptor in the oven for 30min at 110 Degrees Celcius.
When it done make sure you use gloves or just don't touch the adaptor
for at least half an hour, the clay is still soft from the warmth and needs
to harden while cooling down.
Step 6: Succes!
If you went trough all this hard labor to kill yourself make sure you write you parents
a nice letter.
a nice letter.
