Introduction: Summer Sewing Project : Beach Towel for Two
It's summer and therefore: time for the beach!
No more sticky sandy lines between your beachtowels anymore with the Towel for Two!
Easily button up your towels together to get a perfect kingsized towel for 2.
The towels also have a pocket at the top in which you can store your clothes thereby transforming the pocket automatically into a pillow! Also handy to store your belongings in when you are going for a swim and you don't want to keep your valuables exposed!
So if you want to be comfortable, cosy, stylish and sand free this summer: follow the following steps and make your very own towel for two!
Step 1: What You Need:
2 Towels of 80cm x 160cm
1 Towel large enough to cut 2 pieces of 40cm x 50cm from
Cotton Fabric
9 Larger buttons
4 Smaller buttons
Ruler
Pins
Chalk
Needle and Thread
Sewing machine
Iron
You can use whatever towel size you want, but further measurements given in this tutorial apply to the above measurements.
Cotton Fabric
9 Larger buttons
4 Smaller buttons
Ruler
Pins
Chalk
Needle and Thread
Sewing machine
Iron
Step 2: Take Two Beach Towels of the Same Size or Cut Two From a Larger Towel Fabric
cut two towels with a measurement of 80cm cm x 160cm
Step 3: Cut Out Two Smaller Pieces
Cut two pieces from another towel, preferably a different colour than your large beach towels.
These pieces should measure 40cm x 50cm.
TIP: Its easier to draw one out, fold over, pin together and cut 2 in one go! This saves time and you're sure to have two of equal size.
Step 4: Cotton Fabric Strips
Cut a large strip of fabric with a width of 15cm for the larger towels
and a width of 10cm for the smaller ones.
Step 5: Fold and Press
Fold the sides of the strips towards the middle and press
Step 6: Fold Again
Fold over again and iron.
Now you have a nice strip to sew around your beach towels.
Step 7: Add Length
Your strip should be long enough to go around the entire towel in one piece, if your strip is too short to go around your whole towel:
Get two strips, undo the last fold for both and place them on top of eachother with the remaining fold facing outwards...
Step 8: Add Length Step 2
Sew them together along the red line and trim off close to the line
Step 9: Add Length Step 3
Fold back, now you should have a strip long enough to go around the entire towel.
Step 10: Pin
Pin the cotton strips around your towels, make sure to keep the corners nice and neat!
Step 11: Sewing on the Strips
Sew on your cotton strips using a straight stitch.
Remember to always backstitch at the start and the end!
Step 12: You Should Have
You should now have your two large and two small towels all lined with the strips.
Step 13: Buttonholes
Sew 9 buttonholes on 1 of the large towels along the long (160cm) side.
Mark where you want your buttonholes.
Sew the first buttonhole 7cm away from the top and then add another one every 18cm to evenly divide them along the the whole side.
Make sure to always make your buttonholes 3 to 6mm wider than your button is!
Step 14: Sewing Buttonholes
Every standard sewing machine comes with a buttonhole setting.
Mine in this picture shows the 1-2-3-4 step
1. stitch up
2. stitch across
3. stitch down
4. stitch across
1. stitch up
2. stitch across
3. stitch down
4. stitch across
Step 15: Cut
Cut a straight line between the stitches of your buttonhole using an exacto knife or seam ripper.
Step 16: Marking
Align the strip of the towel with the buttonholes evenly over the strip of the other large towel
Step 17: Marking
Now, go with your pencil or chalk through the buttonholes to mark where you need to sew your buttons.
Step 18: Buttons
I advice to use buttons with a little loop on the back as displayed in this picture because you are working with thick fabric.
Hand stitch them on the markings you made in the previous step!
Step 19: More Buttonholes!
Also sew two buttonholes along the 40cm side on both of the smaller towels.
When you keep a ruler (or measuring tape) beside the 40cm side, you can mark a buttonhole at 13cm and one at 27cm to have them evenly divided.
Step 20: Pin Together and Sew On
Now evenly position the smaller towels on the top of the larger towels, pin them in place and sew them on.
Remember to keep the side with the buttonholes open! So you only sew it on on 3 sides!
Don't forget to backstitch at beginning and end!
Step 21: Sew the Small Buttons On
Using needle and thread, sew the smaller buttons onto the towel so that you are able to open and close the pockets which you've sewn on in the previous step!
Step 22: You Are Finished!
Button the two beach towels together and admire your work!
Step 23: Big Enough for Two!
In this picture the towels are separated and i've put some clothes in the pocket (pillow!) on the right! My cats approved of this project!
Happy sewing and have a beautiful summer!
