Introduction: Summer Watermelon Shark
Hello! Today, I will teach you how to make a watermelon shark that is easy and fun to make. It's a great way to impress and scare the people at your next summer party! This would not be possible without Mikeasaurus. He was a huge help in making this. If you want to make your watermelon shark neater than me, go check him out.
You will need blue jello for the water, Swedish fish for decoration, a watermelon, a melon scooper, a knife to cut the watermelon, and some snacks to put in your watermelon shark.
Step 1: Cut One End at an Angle
First, you will need to cut your watermelon at an angle. This will be the base of your watermelon shark. You don't need to cut at an angle, but it is recommended.
Step 2: Cut Mouth Opening
Now, you need to cut the mouth opening, it should be about 1/4 of the watermelon.
Step 3: Remove Watermelon Insides
Then, you need to remove the watermelon insides, keep it, and try to cut it nicely. This was a mistake I made while I was cutting. It made the mouth look weird when I filled it in later in the steps.
Step 4: Trim Mouth
When you are done, trim the mouth for the teeth. Ensure you don't fully cut off the mouthpiece, just cut until you see the white.
Step 5: Cut Teeth
Now, it's time to cut your teeth. Cut at a zig-zag pattern and don't remove the off cuts.
Step 6: Make Fins
Make fins off of the off cuts and use toothpicks to attach them together.
Step 7: Fill It Up With Treats and Add Jello Water
Now, time to fill up your watermelon shark with all of your snacks. I put Swedish fish, watermelon, blueberries, and green grapes. Then, I put jello around it to make it look like water.
Step 8: DONE!
Now you're done with your watermelon shark! Hope you have fun at your next summer party with this delicious and impressive treat!
