Introduction: Sump Pump Alarm
I have had so many times over recent storms, have a sump pump fail, maybe thru paranoia I assembled this sump pump notification system, so even if I’m away from home I will get a message on my iphone5 if flooding begins to occur.
Parts used
arduino uno rev 3
sim900 gsm/gprs shield
one 10k resistor
sim card (I used an at&t go phone card from Wal-Mart)
misc wood, brackets, and conduit I had laying around (see photos)
code
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 8); //gprs shield attached to pins 7 and 8 for software serial connection
const String phoneNumber = "+1xxxxxxxxxx"; //the phone number of the phone to send the text message to, remember to include the country code before the number
const int sensorPin = 2; //the water sensor is attached to pin 2
boolean flooded = false; //set the flooded variable to false
boolean messageSent = false;
void setup(){
mySerial.begin(19200); //19200 is the GPRS baud rate, this must be fixed
//Serial.begin(19200);
pinMode(sensorPin, INPUT);
SIMpower();
delay(20000);
void SIMpower()
// software equivalent of pressing the GSM shield "power" button
digitalWrite(9, HIGH);
delay(1000);
digitalWrite(9, LOW);
delay(5000);
void loop(){ //we loop through this area
if (digitalRead(sensorPin) == HIGH){ //if the sensorPin is high, current is being passed into it, so the sensor must be submerged
flooded = true; //the basement is therefor flooded
} else if (digitalRead(sensorPin) == LOW){ //otherwise if it has no current
flooded = false; //the sensor isn't submerged
messageSent = false; //we can reset the messageSend, so that if it becomes submerged again, we can end another text message
if ((messageSent == false) && (flooded == false)){ //if we havent yet sent a message, and the sensor is submerged
sendTextMessage(phoneNumber, "Your basement is flooding [Arduino]"); //we send the text message
messageSent = true; //we set messageSent to true so that we don't keep sending text messages (this woulld cost a lot of money)
void sendTextMessage(String phone, String data){ //sends a text message to phone, containing data
mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(100);
mySerial.println("AT + CMGS = \"" + phone + "\"");//send sms message, be careful need to add a country code before the cellphone number
delay(100);
mySerial.println(data);//the content of the message
delay(100);
mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
delay(100);
mySerial.println();
delay(5000); // give module time to send SMS
SIMpower(); // turn off module
Parts used
arduino uno rev 3
one 10k resistor
code
void setup(){
SIMpower();
delay(20000);
void SIMpower()
delay(1000);
delay(5000);
delay(100);
delay(100);
delay(100);
delay(100);
mySerial.println();
