Introduction: SunHaven Module: an Affordable, Net-Zero, Passively Heated/Cooled, 3D Printed Housing Solution
Hello! I am a rising junior at Rossview High School in Clarksville, Tennessee. I love everything engineering, and I especially love using CAD to solve problems. I have been using Instructables for a long time, both for creating things that I have found cool on here, and for inspiration for my own projects. I recently discovered that there were competitions on this site, and was eager to check them out.
I had been tinkering with CAD software for a bit, when I discovered this contest, and thought it would be a perfect place to showcase and test my skills.
I came across the problem of energy burden, with my involvement in the YMCA Youth in Government, and YMCA of the USA Changemakers program. From this I learned that energy expenditure is significant for many parts of rural Tennessee, and in other states in Appalachia. I had been thinking about what can be done to alleviate this issue for a few months, and seeing this competition, I knew that it would be perfect.
After a long journey of development, I'm proud to present this project.
Table of Contents
Research: Step 1-13
Planning: Step 14 & 15
Sketching: Step 16-23
Revit: Step 24-34
Fusion 360: Step 35-44
LEED Certification: Step 45-47
Physical Model: Step 48-63
Final Words: Step 64
Credits: Step 65
Notice: These are the supplies used for rendering; the supplies for the 3D prototype will be listed later.
Physical
- Pencils
- Papers
- Colored pencils
- Ruler
- Eraser
Software
- Autodesk Revit
- Autodesk Fusion 360
For documenting
- Smartphone/Camera
Step 1: Background
I live in Tennessee — a state known for its music, mountains, and all else associated with the south. But behind all that, there’s a quieter crisis: energy insecurity. During the colder months, especially in Appalachia and rural areas, too many families are forced to choose between heat, food, or medicine.
Tennessee ranks near the bottom of the country in energy affordability. What really stuck with me was from a 2025 ThinkTennessee report:
Energy insecurity has become the quiet emergency in our state — and the burden is heaviest on the people who can afford it least.
That hit home.
I began researching how housing design could help tackle this — not just with better appliances or solar panels, but by fundamentally rethinking how we design and build homes for energy efficiency from the ground up.
Sources: Think Tennessee
Step 2: The Problem
In most of Tennessee, low-income families live in older, drafty homes. These structures leak heat in the winter and trap it in the summer. Utility bills skyrocket, sometimes exceeding 30% of a household’s income — triple the national average energy burden.
Here’s the reality:
- Over 400,000 households face “high” or “severe” energy burden.
- State assistance programs like LIHEAP or Home Uplift only reach a fraction of those in need.
- The cost of energy is often unbearably high due to lack of energy grid infrastructure.
- In the current state it is simply too costly/too inefficient to get energy to rural houses in TN, hence the high energy burden.
ACEEE's 2017 report summarized it:
In parts of rural Tennessee, the choice between heating your home and feeding your family isn’t rare — it can be the norm.
This is not just a comfort issue. It's about health.
Step 3: Research
Passively cooled home in Germany
Source: BobVila
I started by searching through techniques used in other parts of the world to save energy on heating and cooling, namely in places that have historically had to develop ways of defending against the cold, and where energy is more expensive than the US.
I came across several such techniques, and was impressed by how simple some mechanisms were. Even further, I was impressed by the fact that houses passively heated and cooled houses look and function in most other ways just like traditionally heated and cooled houses.
Step 4: What to Implement
I started by visiting ResearchGate, and looking through any publications relevant to passive heating and cooling, saving energy, and cheaper construction. After narrowing these down, I sorted by methods that are cheap to install and don't aesthetically detract from the house. Realizing that these concepts would be hard for me to grasp together, I started by breaking them apart and researching them individually.
Step 5: Solar Chimney
Diagram showing how Solar Chimney functions.
Source: University of Calgary
A solar chimney is a tall hollow construction that uses the sun’s heat to move air. As the sun warms the chimney, the air inside gets hot and rises. This pulls cooler air into the building from below, helping to keep the space cool and fresh without using fans or electricity.
Step 6: Trombe Wall
Diagrams showing Trombe wall's functions at night vs during the day
Source: Image source removed from internet (Error 404)
A Trombe wall is a thick wall that absorbs heat from the sun during the day and slowly releases it into the building at night. It usually has a dark surface and a glass panel in front to trap heat, like a greenhouse. This helps keep the inside warm without using heaters.
Step 7: Overhang
Diagram showing how overhang is used with a Trombe wall to keep a house warm in winter and cool in summer.
An overhang is a roof or shade that sticks out over windows or walls. In the case of Trombe walls, it blocks the high summer sun to keep the building cool, but lets in the low winter sun to warm the space. This helps control temperature naturally through the seasons.
Step 8: Solar Panels
Solar Panels in Northern Hemisphere facing South.
Source: Forbes
For a house that makes energy cheaper, I already knew that solar panels were a must. However, I did not know the most effective way of positioning them. I learned that the way to position your solar panels depends on where you are.
As a general rule:
Solar panels should face the equator—south in the northern hemisphere and north in the southern hemisphere. The most effective tilt angle is usually close to your latitude. To improve efficiency, tilt the panels 15° more in winter (sun is lower) and 15° less in summer (sun is higher). This setup helps capture the most sunlight year-round.
If the tilt can’t be changed, set the solar panel angle equal to your latitude. This gives the best overall performance year-round by balancing winter and summer sunlight.
Step 9: Construction
Upon further research into materials for the house to be built with, I came across 3D printed housing.
Common materials include:
- Cement-based concrete: The most popular, often reinforced with fibers to improve strength and reduce cracking.
- Mortar-like mixes: Thinner than regular concrete, allowing smooth, layer-by-layer extrusion.
- Additives: Like fly ash, slag, or plasticizers to improve flow, setting time, and durability.
- Insulating foams or polymers (less common): Sometimes used for interior walls or insulation layers.
This is important, because cement-based concrete has a high thermal mass.
Sources: 3DRIFIC
Step 10: High Thermal Mass
Diagram showing high thermal mass flooring being used to keep house warm in winter and during the night, and cool during the summer and daytime
Source: Australian Government YourHouse
Using 3D printing, due to the high thermal mass of what it uses, allows for further passive temperature management within the house. Additionally, this is useful, because for a Trombe wall to function, high thermal mass construction materials are required.
Step 11: Multi-Story 3D Printing
(Old) Idea of 3D Printed Houses (Flat roof, beveled edges, one story)
Source: ArcTern Ventures
Up till now, I was under the impression that 3D printed houses would be unable to be multiple stories and always had to have round edges, and flat roofs.
Upon further research, I learned that more modern 3D printed houses can be made multiple stories, have any roof type, as well as have sharp edges.
Step 12: Multi-Story 3D Printing (pt. 2)
Images showing 3 new improvements to 3D printed homes: Hybrid Prefabricated-3D Printed homes, Multi story 3D printed homes, and 3D printed homes with sharp edges.
Sources: 3D Printing Industry
Through this research, I became confident that I could create a house that could address all of the energy needs of Tennessee while also looking aesthetically appealing, cheap to construct, fast to deploy, and conserving space (as much as all of these can be balanced).
Step 13: Windows
Diagram showing how windows are used for passive heating/cooling
Source: Fity
In continuing my research into passive and sustainable energy solutions, I learned that windows play a key role in passively cooling the house during summer. Summers in Tennessee are very warm, so the number of windows in the house and where the windows are to be placed needs to be carefully thought through.
Step 14: The Solution
So, I asked: What would a house look like if it was designed specifically to fight energy poverty?
After having researched these methods, I came up with a solution.
The answer became the SunHaven Module — a compact, modular, 2-story condominium-styled home designed to:
- Capture free energy from the sun in winter
- Ventilate naturally in summer
- Run on minimal active energy systems
- Be built off-site and with 3D printing for cost savings and rapid deployment
- Have enough space to house up to 2 families.
The SunHaven Module is not a luxury eco-home — it's a practical, scalable model for Tennessee’s rural working-class families.
In short: It tackles two problems at once, the high cost of housing and the high energy bills faced by rural families in Tennessee.
Step 15: Site Details
While I feel that most of rural Tennessee would benefit from this house design, some parts are better suited than others.
Counties in Tennessee that are a best fit for SunHaven (in no particular order):
- Campbell County
- Scott County
- Hancock County
- Clay County
- Fentress County
- Jackson County
Why these counties?
- Part of the Appalachian Highlands region.
- Documented as having some of Tennessee’s highest energy burdens.
- Underserved by major utility assistance or weatherization programs.
Source: Environmental and Energy Study Institute
This housing solution is primarily catered towards Tennessee, but it will also work in the following states (and due to the following reasons):
Kentucky – High energy burden in rural Appalachian communities.
West Virginia – Widespread energy poverty and outdated housing infrastructure.
Arkansas – Low-income rural areas with high utility-to-income ratios.
Mississippi – Extreme housing affordability issues and poor insulation in homes.
Alabama – Rural regions face high summer cooling costs and poor access to energy upgrades.
Missouri – Rural families experience severe winter heating costs.
North Carolina – Western counties have aging homes and limited energy assistance access.
South Carolina – Inland areas struggle with inefficient homes and summer cooling bills.
Indiana – Southern Indiana has high utility costs in older, rural homes.
Oklahoma – Energy insecurity driven by rural isolation and extreme weather swings.
Sources: The Department of Energy (DOE)
American Council for an Energy-Efficient Economy
Step 16: Specific Site Details
Image of underdeveloped land in Jackson County. Obtained from Google Earth.
Within rural Tennessee counties such as Jackson, the most viable locations for SunHaven Modules are vacant or underdeveloped residential properties. This is especially the case for those already zoned for housing but lacking modern infrastructure or recent development. These sites often sit unused due to the economic barriers of traditional construction, making them ideal candidates for a modular, net-zero housing solution.
In Jackson County (chosen due to reasons stated above), for example, I identified a specific property that meets key criteria: it's accessible by road, has nearby utility lines, and is situated to take advantage of passive solar design: receiving ample southern exposure while remaining relatively sheltered from prevailing winter winds. Developing properties like this not only reduce upfront land development costs, but also provides underserved rural areas with sustainable, affordable housing.
Step 17: Considerations
Tennessee homes
Credit: Houzz
When roughly sketching my design, I wanted to ensure that it looked nice and would be both comfortable and aesthetically pleasing (in addition to affordable). In creating a sketch outline for this design, I wanted to ensure that the following was implemented in my design:
Site & Community
- Can be integrated into rural TN counties with high energy burden
Aesthetics
- Designed based on common/traditional houses in Tennessee
- Adapted for weather and climate of Tennessee (& other Appalachian states)
Climate-Responsive Design
- Passive heating (Trombe wall, overhangs, thermal mass)
- Passive cooling (solar chimney, air pathways)
- Optimized window placement
Energy & Sustainability
- Solar panels with optimal tilt for latitude
- Net-zero capable structure
- High thermal mass construction (3D printed concrete)
- Low operational costs
Affordability & Construction
- Modular & prefab design
- 3D printed (for reduced labor + waste)
- Adaptable for mass deployment
Scalability & Replication
- Works across Appalachian states
Safety & Comfort
- Natural lighting and ventilation
- Logical layout with privacy for (up to) two families
Community Benefits
- Reduces energy poverty
Step 18: Pen to Paper
Now that I have done enough research to put together a concept, I decided to start by drawing out the house. I find it easier to model things in 3D, if I have a 2D reference.
Step 19: Rough Sketch
I started with a rough sketch to outline my idea. I additionally decided on adding a fenced backyard to house the 'solar tube' to increase natural cooling as outlined in Step 5.
Step 20: Details
I then added shading to the 2nd floor's overhang, and showed how the sun hits the solar roof, and the cavity in the ground for hot air to push cool air into the house.
Step 21: Colorization
I then added color, to show what air is hot and cold, as well as which way it goes, as well as the tube inside the house connected to the one outside to cool the house.
Step 22: Key & Labeling
I then added a key and started labeling.
Step 23: Further Labeling
I then added more labels, and made it more clear that the tube outside the house is in the backyard, and that the other tube is indoors.
Step 24: Further Labeling (pt. 2)
I then added more labels, and incorporated an idea I had: both tubes would be netted and have a closable lid, to make sure nothing accidentally falls in.
Step 25: Dimensions
Finally I added dimensions, by referencing the average family sizes in Tennessee and how much space is required to house up to 2 families.
Sources: US Census Bureau
Step 26: Revit
With the design finalized on paper, I moved on to bringing it into the digital world using CAD. Since the ultimate goal was to 3D print the structure, having precise and detailed CAD models was essential. I had experience with Blender and Autodesk fusion, but I wanted to try something new. While browsing the Autodesk tools online, I came across Revit: an industry-standard software widely used in architectural design.
I was pleased to find that this software, like Fusion 360, had a student license available.
Step 27: Getting Started on Revit
I started by creating my first floor according to the dimensions I had sketched out.
Step 28: 1st Floor Layout
I then added a door and a large window in the 1st floor, mainly to look aesthetically pleasing, and the window is in accordance with Step 13's passive heating/cooling window positioning guide.
I then designed the layout for the first floor. Keeping in mind to leave open wall space for windows to allow air to circulate. (Labels can be seen by clicking image 2 & 3)
After creating a floor, and walls for the 2nd floor, I added windows to the first floor. Again, I was careful to follow Step 13's passive heating/cooling window positioning guide.
Step 29: 2nd Floor Layout
I then went ahead and designed the layout for the 2nd floor. (Labels can be seen by clicking the image)
Step 30: Columns
I then added 2 columns in the front to support the overhang.
Step 31: Roof
I then added a roof with an overhang.
Step 32: How to Add Overhang
To add the overhang, simply add a value to this button when creating the roof.
Step 33: (solar) Chimney
I then added the solar chimney, to the kitchen in the 1st floor, and the master bedroom in the 2nd floor, both places likely to have high heat buildup. Additionally, I added windows here when designing the floor itself.
Step 34: Importing to Fusion
I then imported the file to Fusion 360, but quickly realized that I would not be able to 3D print it as is.
I decided to model each part of it individually in Fusion, to a 1:60 scale. I chose this scale, because my printer is not very large, so I had to choose a size small enough that it could print, but big enough to show detail and the mechanisms for passive heating/cooling.
Step 35: Base
I started by modeling the base.
Step 36: First Floor
I then modeled out the first floor, making sure to model out the windows and the front door. This is so that the passive cooling/heating effect can be felt even in the model.
Note: Please open the last image for an explanation of the purpose of the indent.
Step 37: Second Floor
I then modeled out the 2nd floor. I then covered the bottom to simulate the floor, and the top as well to simulate the second floor above it. Here I realized that an attic would be made, but as it did not contribute to the passive heating/cooling effect, I did not implement that into the design of the model.
Note: I decided against a front window in the model for the 2nd floor, as it does not provide any benefit to the purposes of the model.
Step 38: Twin Overhangs
I then went back to the first floor, and added 2 overhangs, one on the front for aesthetic reasons, and one in the back for the Trombe wall.
Step 39: Roof
I then completed the roof for the 2nd floor of the house.
Step 40: Revision of Solar Chimney
Diagram of a how a Barjeel keeps a house cool in hot climates.
Source: Environment Ecology
While I was designing the solar chimney in Fusion, I came across another technique used to passive cooling of houses in warmer areas.
A Barjeel is a traditional wind tower used in Gulf architecture to cool buildings naturally. It captures wind from any direction and channels it downward into the interior, while allowing hot air to escape. This creates a natural ventilation system that reduces indoor temperatures without electricity. Barjeels are an early form of sustainable design, common in old Emirati and Iranian homes, especially in hot desert climates.
Since I already was adding a solar chimney, and all it needed to make it into a Barjeel was a partition wall, I decided to implement this architecture into my design.
Step 41: (new) Solar Chimney
I then created the solar chimney, with holes and a partition wall to emulate a Barjeel. I made sure to keep it hollow, so that the cooling effect is noticeable even in the model.
Step 42: 3D Models (With Rooms)
With this, I completed the Fusion 360 models for both floors and the base of the house.
Step 43: Revised 3D Models
Having created the 3D models in Fusion 360, I put my models into the slicing software, and realized that for the purposes of a 3d model, it would be better to remove the walls for the 'rooms', as the model is not large enough that the rooms provide realism proportional to the extra filament use. (The base was kept the same)
Step 44: Cost Breakdown
Structure & Shell
3D-Printed Walls $18,000 – $30,000
Floor Slab/Base $2,500 – $4,000
Roof $3,000 – $4,500
Columns & Supports $800 – $1,200
Passive Heating/Cooling Systems
Trombe Wall $1,200 – $1,800
Solar Chimney/(modified) Barjeel Tower $800 – $1,200
Overhangs & Shading $500 – $1,000
High-Performance Windows $1,500 – $2,200
Ventilation Components $400 – $700
Energy Systems
Solar Panel Array $8,000 – $10,000
Battery Storage $4,000 – $6,500
Interior Buildout
Insulation & Interior Walls $2,000 – $3,000
Electrical Wiring $2,000 – $2,500
Plumbing $2,500 – $3,500
HVAC Backup System $1,200 – $2,000
Kitchen & Bath Fixtures $2,500 – $4,000
Flooring, Paint, Trim $2,000 – $3,000
Deployment & Services
Factory Assembly $3,000 – $4,500
Transport to Site $1,500 – $2,500
On-site Installation $2,000 – $3,000
Utility Hookups $2,500 – $4,000
Permits & Inspection $800 – $1,200
Total: $60,400 – $82,800
Sources: COBOD
Step 45: LEED Certification
Since my design is primarily based in green development, I wanted to quantify its renewable impact. Therefore, I decided to simulate a LEED certification.
For clarification: The LEED certification estimate is for the completed design, not for (only) the 3D model's design. It includes credits for items included in the cost breakdown, outline, and Revit file but not necessarily rendered in the .stl file/3D printed.
A LEED certification (Leadership in Energy and Environmental Design) is a globally recognized mark of sustainability for buildings. It signifies that a structure was designed and built using strategies aimed at improving energy efficiency (one of the primary goals of my design), reducing environmental impact (another key goal of my design), and promoting occupant health (integral to all houses, especially mine).
The current LEED version is Version 5.
Compared to Legacy v.4.1, v5 has:
- Stronger focus on carbon – both operational and embodied.
- Higher energy performance baseline – aligned with zero-carbon goals.
- Performance-based credits – actual data matters more than design intent.
- More emphasis on equity – social equity and community health are now integrated.
- Resilience and climate adaptation – new requirements for future-proofing.
- Simplified credit structure – fewer overlapping credits, clearer intent.
- Material transparency + embodied carbon – deeper look at full lifecycle impact.
While my design has not been built in actuality, I was able to use the data that I had collected from the mean and median savings and climate impacts of implementing aforementioned passive heating/cooling methods (Steps 5-10, 42) in other countries and houses, to determine the impacts of my design.
After looking online, I learned that U.S. Green Building Council has a website in which one can simulate how whether a building qualifies for a LEED certification and which certification it qualifies for.
Sources: U.S. Green Building Council
Step 46: LEED Score Criterion
Image showing criteria for credits.
Credit: U.S. Green Building Council LEED Scorecard
The LEED certification v5 awards credits for meeting requirements in the following categories:
Location and Transportation
Credits for selecting sites that reduce the need for car travel, encourage walkability, and support access to public and low-emission transportation.
Sustainable Sites
Credits for protecting ecosystems, promoting biodiversity, managing rainwater, and reducing site-related environmental impacts.
Water Efficiency
Credits for minimizing water use indoors and outdoors, improving fixture performance, and implementing effective water reuse and management strategies.
Energy and Atmosphere
Credits for optimizing energy performance, using low-carbon and renewable energy sources, enhancing building commissioning, and reducing refrigerant impacts.
Materials and Resources
Credits for using products with lower embodied carbon, supporting a circular economy, minimizing construction waste, and promoting transparency and responsible sourcing.
Indoor Environmental Quality
Credits for ensuring healthy indoor air, thermal comfort, natural and high-quality lighting, and acoustic performance to enhance occupant well-being.
Integrative Process
Early-phase collaboration across disciplines to identify synergies among systems for water, energy, and site performance.
Innovation
Credits for strategies that go beyond existing LEED requirements, pilot credits, or exemplary performance.
Regional Priority
Credits for addressing local environmental, social, and public health challenges specific to the project’s location.
Step 47: LEED Score
After filling out the U.S. Green Building Council interactive scorecard, I was able to project that my design would score a 87/110 with a ~5 credit margin of error (based on the fact that some aspects of my design are harder to find data supporting the concrete impacts of).
Even with this margin of error, my design scores (at minimum) an 82/110, which is still well withing the 80 credit minimum for a Platinum Certification, which is the highest LEED certification.
Step 48: Physical Model: Supplies
Materials
- PLA Filament (~45g ± 2g)
- Small piece of plastic ~1.5in² ± 0.25in² x 0-0.5cm(5mm)
- Super Glue
Equipment
- 3D printer- Creality K1 SE
- Smartphone/Camera
- USB Drive - to transfer GCODE (Not needed for cloud based printers)
- Wire cutter
Software
- Slicing Software - Orca slicer
Optional but suggested
- Soft cloth, plastic, or paper (for blending of glue)
Step 49: Slicing Models
I then used Orca slicer (a free, open-source 3D printing slicer developed as a fork of Bambu Studio) to slice the models for 3D printing.
Step 50: 3D Printing Components
I then started started printing the three main components.
Note: When I was printing the 2nd floor, I incorrectly sliced the model, which resulted in longer than expected overhangs.
Step 51: Reference Minifigure
To give a sense of scale, I also printed a minifigure of a 5'9" person to 1:60.
Step 52: Post Processing
To simulate the opening in the solar chimney (click on image in step 5 for clarification), I added a small indent into the base using the nozzle of the 3D printer.
Step 53: Model Assembly
To start, lay the 1st floor model diagonally across the 2nd floor model like so.
Step 54: Gluing the Plastic
Apply beads of glue in a square pattern to the Trombe Wall like so, and attach the clear plastic. (Click on the image)
Step 55: Add Glue to Bottom of 1st Floor
After completing the Trombe Wall, flip the 1st floor upside down and apply glue like so. Apply glue to all surfaces that will touch the base, and extra glue to bottoms of the columns.
Step 56: Attach 1st Floor to Base
After that, simply put the 1st floor on the base, making sure that the solar chimney does not hang off the side of the base. (Click on image 2 for clarification)
Step 57: Blending of Glue
Take a piece of any material that is soft or paper, and blend the glue along the seam lines to ensure a clean connection.
Step 58: Attachment of Minifigure
Add a bead of glue to the place specified. (Click on image)
Step 59: Add the Figure
Add the figure to the place glue was added, and push down the figure to ensure a clean connection and push out any air bubbles.
Step 60: Preparation for 2nd Floor
To add the 2nd floor, add beads of glue to all upwards facing surfaces like so. Make sure extra glue is on the solar chimney and the dividing Barjeel wall.
Step 61: Adding 2nd Floor
Simply add the 2nd floor along the corresponding place on the 1st floor. Make sure to align the solar chimneys.
I would recommend using the chimney as a guide to orienting the 2nd floor on top of the 1st one.
Step 62: Blending of Glue
After adding the 2nd floor, make sure to use the same material from step 59 to blend all the beads of glue from the connection of the 2nd floor.
Step 63: Completion
With that, the 3D model is complete!
Step 64: Final Words
Born of a Community Need
The SunHaven Module represents to me more than just an engineering project. It is a solution born of my time with Youth in Government, and living in the American Southeast. It's a response to a real crisis affecting hundreds of thousands of families across Tennessee and Appalachia. Through months of research, design, and prototyping, this modular housing concept demonstrates that affordable, energy-efficient homes are the future of Tennessee.
Why This is Different
Unlike traditional housing solutions that treat energy efficiency as an expensive add-on, the SunHaven Module integrates passive heating and cooling into its very foundation. By combining modern techniques like Trombe walls and ancient techniques like Barjeels with modern 3D printing technology, I tried to create a home that works with the environment rather than against it.
The projected cost of $60,400-$82,800 makes this solution accessible to the families who need it most, while also ensuring its financially feasible for construction companies. The (projected) LEED Platinum certification potential proves to me that houses incorporating both that sustainability and affordability, not only are possible, but are the way forward.
Looking Ahead
In this house, I wanted to incorporate many systems and technologies that make this house as environmentally sustainable as possible, while retaining visual appeal, and space. Moving forwards with this project, I hope to be able to share my findings with builders and architects near me.
The Bigger Picture
Energy poverty isn't something that can be fixed with just one house. It requires a complete rethinking of our approach to housing. The SunHaven Module shows that with a future forward design and new technologies, we can create homes that do more than just provide shelter.
As a rising junior passionate about engineering solutions for pressing problems, I believe the future of housing in the Southeast lies in designs like this: practical, sustainable, and built with specific problems in mind.
Step 65: Credits
I wanted to take a second to thank those that made this project possible.
Special Credits
- Autodesk: Having a free student license available
- The Energy and Resources Institute: Introduced me to renewable construction
- YMCA Youth in Government: Introduced me to energy burden issues
- My Family: For bearing with me while my 3D printer made lots of noise
- Instructables: For providing this platform for me to learn from and contribute to
Research Credits
- Think Tennessee: Energy insecurity research and statistics
- Tennessee Housing Development Agency: Housing affordability data
- Tennessee Department of Environment & Conservation: Environmental impact studies
- American Council for an Energy-Efficient Economy (ACEEE): Energy burden analysis
- U.S. Department of Energy (DOE): Energy assistance program data
- Environmental and Energy Study Institute: Regional energy burden mapping
- University of Calgary: Solar chimney and overhang diagrams
- Australian Government YourHouse: Thermal mass principles
- ResearchGate: Academic publications on passive heating/cooling
- U.S. Green Building Council: LEED certification guidelines and scorecard
- COBOD: 3D printing construction cost estimates
- Iconbuild: Modular construction pricing
- 3DRIFIC: 3D printing materials research
- Solar Reviews: Solar panel system costs
- Home Advisor: Construction cost benchmarking
- US Census Bureau: Tennessee family size demographics
- World Population Review: Population and housing statistics
- General Services Administration: LEED certification processes
