Introduction: Sunnycat? Yes, That Obscure Character. You Got It, Kid.
Part mermaid. Part cat. A quarter sliver sun. It’s Sunnycat! This character that has made an appearance in all of TWO Gabby’s Dollhouse episodes has struck a chord with my three year old. So, of course Mommy obliges and makes her dreams a reality. Sunnycat for all!
- headband base
- orange tulle
- orange, white, and fuchsia felt
- varying pink, orange, purple iron on vinyl
- iron on hemming adhesive
- felt glue
- wire
- decorative string
- elastic
- thread and needle
- orange or pink shirt
Step 1: Headpiece
Headpiece first and foremost. I knew this part of the costume would get some heavy use so I went with sturdy construction before cosmetic.
Wrap the tulle around the headband in tight overlapping layers. Lock in place by sewing along the back edge.
Step 2: Headpiece Breakdown
Cut out scale shapes of 1 1/2”-2” in all of the colors. Arrange in overlapping pattern and heat press in place. Measure proper sizing on head and create a scalloped scale pattern on the backside to be cut.
Step 3: Headpiece Bits
Cut orange triangles for the ears depending on wearer’s size that curve slightly on the outside edge. Cut proportionally smaller triangles in fuchsia for the inner ear. Felt glue to attach together.
Step 4: Headpiece Assemble
Cut orange sun, and yellow circle for the sun’s center. Assemble pieces for attachment.
Position scaled headpiece so the majority hangs over the front portion. Sew it to headband along the mid-line. Sew folding the bottom 1/4” of the ears on the backside of the headband partially overlapping the sides of the scaled headpiece. Carefully iron the ear’s fold to solidify the bend. Felt glue the sun toward the front of the headpiece.
Step 5: Mermaid Tail Body
Use white felt and chalk. Measure the wearer from chest to mid-calf/knee. The width should be just big enough to cover the chest. Create the tail a little less than chest width long and about chest width extending out, the double leafed tail is extended out from there. Fold the tail in half length-wise and draw a small curve along the inner edge to be cut for the chest detail.
Cut iron on vinyl in approximately 2” wide scales of varying pinks, purples, and oranges.
Step 6: Mermaid Tail Scales
Beginning with the end of the tail, pattern scales in an overlapping formation of rows. Periodically iron sections to the felt to lock in place before moving on to other rows. Flip the tail over and cut off excess trim.
Step 7: Tail Attachment
Position the tail on the shirt just above armpit level. Pin in place. Turn inside-out, and adhere the hemming adhesive tape with an iron.
Step 8: Tail Wag
Cut wire to length of tail. Cut scrap felt to cover wire, and attach with iron on adhesive. Cut length of decorative string from the person’s arm when extended out down to the bottom of the tail. This will be used to “wag” the tail. Connect the string under the felt covering. Create a bracelet from elastic and sew the string together with the elastic bracelet.
Step 9: Finale
Sunnycat in action.
