Super-Citrusy Room and Linen Spray
66,280
354
23
Introduction: Super-Citrusy Room and Linen Spray
Don't throw out the perfectly good spray bottles that perfumes or other over-priced beauty products are sold in.  We probably pay more for that bottle than for the product anyway!  Instead, reuse the packaging to make new, and adorable, cleaning products.
This project is a great room or linen spray on it's own, or a base for something a little more elaborate.  And since it is just citrus and vodka, if you like, it could also make a nice additional to your bar : )
The vodka and citrus fruits have anti-bacterial and anti-fungal properties that will freshen up a room or closet without additional chemicals.
Ingredients
Lemons
Limes
Oranges
Vodka
Water
Materials
Empty Perfume Bottle (Spray bottle)
Jar (Reused food jar)
Tools
Knife
Cutting Board
Steps
  1. Remove label from bottle (the vodka helps with this as well).
  2. Slice rind of lemon, lime and orange.  Just using the rind will minimize the amount of sugar that gets into the spray.
  3. Put rinds in a jar and fill with vodka.
  4. Cover and let sit for a few days.
  5. Remove a few pieces of rind and cut into very thin strips.
  6. Put thin strips in the spray bottle.  This will not only look lovely, but continues the infusing process.
  7. Fill half of the spray bottle with the vodka mix and the rest with water.
Optional - Add add a few drops of your favorite essential oil to the mix.  Ginger, lavender or mint are good choices. Mixing in small batches gives you plenty of chances to try new scents.
Spring Cleaning Contest
Second Prize in the
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    23 Comments
    humblebug
    humblebug
    11 years ago on Introduction
    hey annahowardshaw, i made one for myself, used 5% vodka, a mixture of orange and grapefruit rinds...my problem is it doesnt smell so good... i was thinkin if its because i mixed fresh and ripe rinds... please help...
    also, im thinking if its possible to ethyl alcohol instead of vodka...
    what do you think?
    thanks in advance...
    Browncoat
    Browncoat
    Could prob also be a body spray, right? (I LOOOOVE citrus smells!)
    nightmarefairy
    nightmarefairy
    Reply 11 years ago on Introduction
    i bought a jar of a product like this, made with grapefruit and keep it in the frig. its a wonderful refresher during the hot summer! p.s. its lasted almost 5 years, since it takes very little to make you feel fresh.
    annahowardshaw
    annahowardshaw
    Good idea! I don't see why that wouldn't work. The only thing is that I'm not sure how long the scent would last or how that might relate to infusion time.
    Oh, and brand of vodka might come into play in terms of how strong the smell of the alcohol is and if it lingers at all.
    dyanii
    dyanii
    Also the pure alcohol may dry your skin more than you want it to. Be sure to also use some sort of moisturizer!
    sbabb
    sbabb
    Hey I was wondering if you could use tequila for this? I don't really drink much so all I have is a bottle of tequila left over from New Years lol
    annahowardshaw
    annahowardshaw
    No! Rubbing alcohol would be okay for surface cleaning (which you could also use this for), but since it should not be inhaled and can cause skin irritation, spraying it around a room would no be advisable. Even if it evaporates quickly, and doesn't pose too much a hazard, it does has a stronger smell, so it may overpower any other scent anyway.
    minerug
    minerug
    From an organic chemistry point of view, Rubbing alcohol (iso-propanol) would dissolve the oils in the lemons better than ethanol, but as you said; it's not really very good for you...
    tinker234
    tinker234
    what could i use i cant ude vodca suggjestens
    annahowardshaw
    annahowardshaw
    You could add the lemon/lime rinds to water to infuse, but I think it would be far less concentrated. You could add some additional essential oil to make up for it. Citrus does have disinfectant qualities on its own, so there would still be that element, but again, just not as strong.
    If I find a better alternative, I'll let you know!
    Dgidgi
    Dgidgi
    Thanks for sharing
    My question is that if there is a risk of, with the time, the linen ends up stained... I mean, if I moisture it up and ironed and let them for weeks in the closet, could it stain? (If I wrote something wrong, please, excuse that messy english of mine, it's, of course, not mother language)
    annahowardshaw
    annahowardshaw
    You wouldn't use enough to actually dampen the sheets at all. You'd only used a few sprays either in the dryer or a few inches above the sheets on the bed. The alcohol will evaporate pretty quickly.
    You could also use fewer citrus rinds to reduce the risk further.
    And if you have delicate and/or expensive fabrics, I would do more research before just trusting me : )
    Dgidgi
    Dgidgi
    Thanks for the explanation, I'll try with a little more precaution, then
    *Ü*
    annahowardshaw
    annahowardshaw
    I think rum has more sugar, so I wouldn't! If you were going to you'd want a high alcohol percentage and obviously, white rum over dark.
    TT-MON!
    TT-MON!
    Just wondering...can you use rubbing alcohol instead of Vodka. I can drink the Vodka while making this! :)
