Introduction: Super Easy Crochet Cluster Bunch Blanket
Double Crochet Cluster stitch adds a beautiful texture to any of your crochet projects. Its a stitch which looks lovely in any form and it works up pretty quick. There are many variations to a Double Crochet Cluster stitch. Be it a 2 loop Cluster , 3 loop Cluster or a 4 loop cluster , this stitch always makes the finished project admirable.
Today am sharing the pattern for Super Easy Crochet Cluster Bunch Blanket. The pattern uses Double Crochet cluster stitch worked in bunch which gives the blanket lovely texture and volume. It's a One Row Repeat pattern. The repetitive nature of this pattern makes it super easy to memorize and fun to work up. You can easily make them as small as you want, or as large as you want. Crocheted Blankets are often the best choice to give as gifts to your loved ones.
Visit https://rajiscrafthobby.blogspot.com/2022/06/super-easy-crochet-cluster-bunch-blanket.html
Cake Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 100 Chains for the turning chain.
This measures around 38 inches.
You can adjust the size of the blanket by altering these stitches according to your requirement.
Start with any multiple of 5.
Step 3:
Round 2:-
In the 5th Chain from the hook make, (1 Double Crochet Cluster, Chain 1 , 1 Double Crochet Cluster)- all in the same stitch.
Skip 2 Stitches.
In the next stitch make , (1 Double Crochet Cluster, Chain 1 , 1 Double Crochet Cluster)- all in the same stitch.
Repeat((1DC Cluster , Ch 1 , 1 DC Cluster), Skip 2)
1 Double Crochet in the last stitch.
Once you reach end, Chain 2.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
- Insert the hook into the 1st chain from the bottom.
- Yarn over and pull up a loop. You should have 2 loops on the hook.
- Turn your project and insert the hook into the first Back Loop stitch.
- Yarn over and pull up a loop. You will have 3 loops on the hook.
- Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
- Lastly, yarn over and pull through 2 loops.
- This will make one Double Crochet.
To Make a Double Crochet Cluster Stitch:-
- Yarn over, insert the hook into the stitch, yarn over and pull through 2 loops on the hook.(This is same as doing a Double Crochet Stitch. It is just that , you don't finish the Double Crochet Stitch and continue doing the first part of the Double Crochet Stitch again and again).You should have 2 loops on the hook.
- Yarn over, insert the hook in the same stitch, yarn over and pull through 2 loops. You should have 3 loops on the hook.
- Yarn over and draw the yarn through all 3 loops on the hook.
Step 4:
Round 3:-
**This round onwards , we will be working in the Chain 1 space from the previous round.
1 Double Crochet is already made while making the turning chain.
(1 Double Crochet Cluster, Chain 1 , 1 Double Crochet Cluster)- in the Chain 1 space
Repeat(1DC Cluster , Ch 1 , 1 DC Cluster) in the each of the remaining Chain 1 spaces.
Once you reach end, Chain 2 and use the Straight Edge Turning Chain to make the turning chain.
Step 5:
Round 4 Onwards:-
Keep repeating Round 3 untill the size needed.
