Introduction: Super Easy Fleece Hat
About: I am a domestic engineer, aka. a stay at home Mom. A former science geek, scenic carpenter, and quilter.
This hat is so easy. SO EASY! You can make one in about 2 minutes.
You will need:
A piece of fleece.  (about 1' X 2')
Scissors
A tape measure.
A head
A sewing machine, or needle and thread.
You can use leftover fleece from another project, or cut up an old sweatshirt or blanket, or buy a cute piece in the remnants section.
Step 1: Measure the Head.
Measure around the head, where the bottom of the hat will go.
Then measure about how tall the hat should be, from the eyebrows, to the top of the head.
For my hat I have a head circumference of about 22" and a height of about 7"
Step 2: Cut the Fleece
Now cut the fleece to the right size. You will want to cut the width of the fleece to 1/2 of the head circumference. In my case, 1/2 of 22" = 11" Don't add any extra inches for the seam allowance, or the hat will be too big, since the fleece stretches.
The length of the fleece should be about three (or four) times the height of the hat. In my case 3x7" = 21".
It's okay to make the length longer. It will give you more fabric to make into the cuff of the hat. You can always trim it, to make the hat shorter, but you can't make it longer.
Now fold the hat in half, right sides together, and get ready to sew.
Step 3: Sew the Hat.
Now sew together both sides of the hat. I like to sew from the corners to the folded edge, that way the fold ends up right in the middle.
Now trim your threads, and turn the hat right side out. Roll up the bottom for the cuff. (mine was a little too short, so I could roll the cuff only once. )
Step 4: Embellish
The hat fits well, but it's a little boring.
I sewed on a patch to spruce it up. You could sew on ribbon, or buttons, or whatever you can think of. You could even just draw on it with a sharpie.
Step 5: Put It on and Go Play.
If you want to sew the cuff in place, so that it doesn't unroll, you can do that. Otherwise, just put it on and stay warm this winter.
