Introduction: Super Easy Friendship Bracelet
About: I LOVE to craft, watch Hamilton, bake, sew, paint, build, and play the flute!
This is one of my favriotes because it is fast to make and is super easy to personalize. This tells you how to make one but I would suggest making two so that you and your friend can both have one!
Step 1: Supplies
You will need some string or yarn, twine can also work but it can be scratcy.
Beads (optinal but they look cool!)
That's it!
Step 2: Measure Out the Yarn
In this step you will want to measure out how much yarn you will need, I am doing ten in. so that I can cut of the ends when finished.
Step 3: Snip!
Cut the yarn at the decided location!
Step 4: Knot
Tie a simple knot at one end by making a loop with the yarn and then pulling the end through it.
Step 5: Beads
This is the part where you will want to add your beads, just put them on the string, I am only usign one but you can use as many as you would like!
Step 6: ANOTHER KNOT!
OK this know is kind of complicated so I practiced on a spare pice just untill I got it right, but you can just try it on your bracelet if you want!
  1. Make a kind of fishing hook with your yarn.
  2. Coil the free end twice around the standing line working back toward the post.
  3. Make one additional coil around the standing line on the outside of the coils just made.
  4. Tighten the knot and slide it on the standing line to adjust tension.
Step 7: Snip! (again)
Cut off the ends so that they are nice and clean!
Step 8: DONE!
