Introduction: Super-Easy Noisemaker
Ever wanted to just make some noise? How about looking for a way to annoy your friends? This is a awesomely easy and quick way to make a cool noisemaker. The noisemaker makes a annoying, loud buzzing sound. Enjoy!
P.S. Sorry for the bad photos. My Power Shot A60 is on its last legs.
Step 1: Gather Materials
To make the noisemaker, you will need:
1 Sheet of Paper
2 pieces of Tape
1 Plastic Straw
Tools:
Scissors
1 Sheet of Paper
2 pieces of Tape
1 Plastic Straw
Tools:
Scissors
Step 2: Cut and Prep the Straw
If your straw has a flexible joint, cut that off.
Then, squish the straw by pressing it against the table, counter, or any other surface. It will need to be pretty flat. Next, take your scissors and cut the sides off of the squished end of the straw, at a diagonal.
This piece will vibrate in your mouth, causing the buzz effect.
Step 3: Add the Amplifier
Coil the piece of paper and tape to the straw. I found it was easier to tape the coiled paper on to the straw first, and then add the piece of tape that keeps the coil coiled. Remember to leave the pointy cut edge of the straw facing out.
Step 4: USE!!!!!!
To use the noise-maker, put the pointy end of the straw in your mouth. When you blow, the air causes the two flaps to vibrate, creating the buzz!
Thanks for reading!
Thanks for reading!
