Introduction: Super Efficient Joule Thief DIY
A joule thief is a minimalist Armstrong self-oscillating voltage booster that is small, low-cost, and easy to build, typically used for driving light loads.It can use nearly all of the energy in a single-cell electric battery, even far below the voltage where other circuits consider the battery fully discharged; hence the name, which suggests the notion that the circuit is stealing energy or "joules" from the source. The term is a pun on the expression "jewel thief": one who steals jewelry or gemstones.
Super Efficient Joule Thief DIY to steal all the last energy from a battery and without any Toroid coil. Save your time to get more effect. In this project i will shows you the combination simplicity of the circuit and a few variants on the design which add extra components to improve efficiency to make one.The materials of this project is a single, general purpose small NPN 2n2222 transistor A331, Resistor 5.6K Ohm 1/4W,10nf ceramic capacitor 103, OA90 Germanium signal diode, 5mm round white led, 20 mA, 3.2 V (Light Emitting Diode) and 83uH tiny Inductor instead Toroid coil. Stay Tuned and Enjoy! Please click the "like" button, subscribe my channel, and share this with your friends... To support my "work" every little bit helps! Watch the "ADS" THANKS....
Step 1:
Make It Glow! Contest
5 Comments
7 weeks ago
You said, "A joule thief is a minimalist Armstrong self-oscillating voltage booster", but that is not true. Wikipedia used to say this, which is probably where you got it from, but Wikipedia has since been corrected. A Joule Thief is a blocking oscillator. Other than that, I love your Joule Thief -- it's oscillation is nice and strong. You could make the construction less expensive by taking the three 82uH inductors in series and replacing them with one 246uH (=82x3) or something close like 240uH or 270uH -- you'll have to play around to find the best ratio. In my tests, 100uH as L1 and 270uH as L2 works fairly well, along with 100nF. Using more efficient (and more expensive) inductors will give you a more efficient Joule Thief.
Question 1 year ago
Why are you using two diodes? Why are you using (3) 82uH inductors in series instead of one larger? and the picture shows the emitter going to the positive side of the LEDs.
3 years ago
This is not a joule thief (Blocking oscillator).
This is a simplified Colpitts oscillator.
6 years ago
3 things...
1) The schematic drawing shows a short across the LEDs
2) The schematic drawing and Fritz like diagram shows the germanium diode basically shorting the battery.... the cathode should be pointing to the + side of the battery to help with flyback voltage and
3 The visual portion of the above Fritz like diagram shows the battery connected reverse polarity (Look closely at the battery holder).
Otherwise, yes this should work.
6 years ago
All the other joule thief instructables on this site include a circuit diagram but this one. Trying to capture the fleeting one in the video just doesn't work. Would like to try making this one but without a circuit diagram . . . ?
