Introduction: Super High Gloss Resin Game Table
Make a high gloss resin game table that will last for years and years!
Step 1: Watch the Short Video Tutorial Here!
Step 2: You'll Need
22" x 22" x 3/4" plywood
Two 22" x 1 1/4" wood trim
Two 22 3/4" x 1 1/4" wood trim
Wood glue
E-6000 Spray Adhesive
Americana Multi-Purpose Sealer
DecoArt Dazzling Metallics (in a matching color)
Paintbrushes
Step 3: Cut, Glue and Seal
Glue the 22" x 1 1/4" pieces to opposite sides of the plywood
Glue the 22 3/4" x 1 1/14" pieces to the remaining sides of the plywood
Paint the trim with the Dazzling Metallics
Generously coat the checkerboard with the sealer on both sides
Cut enough strips of scrapbook paper to frame the table
Coat both sides of the scrapbook paper with sealer
*This will ensure the the Glaze Coat doesn't darken the paper
Step 4: Mix, Pour and Pop!
Glue your strips around the table with the spray adhesive on two sides
Cut the ends at 45˙ angles to create mitered edges
*For this next part you'll want to work outside
Mix 1 quart of Glaze Coat for 5 minutes
Evenly pour onto the table
Pop the bubbles with a long arm lighter or small torch
Cover and let dry overnight
Add another layer of Glaze Coat if you haven't filled it enough
