Introduction: 1 Up/Super Mushroom Lightbulb
This is a light bulb that is made to look like Mario's favorite food, a mushroom.
Tip, don't worry about mistakes, the maker comes off if you rum the bulb with your finger.
Warning, the marker comes of with you finger, avoid touching marker you want on the bulb.
Step 1: Materials
A light bulb
Tape(if you can draw strait lines, you won't need this)
black sharpie
color choice sharpie(depends on what mushroom you make, I'm using red)
water bottle cap
2 steady hands
black sharpie
water bottle cap
2 steady hands
Step 2: Base Line
I am completely incapable off drawing a strait line, so i put tape around where the neck of the bulb ends. i then used the red sharpie to make the line and took the tape off. use your finger to rub any ink that went under your line off.
Step 3: Make the Circles
this is by far the most difficult step.using the bottle cap, make circles with your sharpie. I found it much easier if i held the cap in one hand, the sharpie in the other, and the bulb in my toes. after you're done fix up any ink you may have rubbed off.
Step 4: Color In
Simply color the rest of the top of the bulb.
Step 5: Add Eye and You're Done
give him the classic little line eyes with your black sharpie. after that your done. I was also informed that lighting it up will cause the ink to burn and smell bad. Use it just for display purposes.
