Introduction: Super Nintendo Hard Drive
I had an old SNES game that didn't work any more, but I didn't want to throw it away. I stumbled upon a cool use for it - an external hard drive enclosure!
I've seen people put hard disks and larger SSDs into SNES cartridges, but not a M.2 (2280) SSD which I also had laying around, so I thought I'd give it a try and share my process.
One thing I tried hard to achieve was to make the cartridge appear stock, unless you look at the bottom of it. I didn't want to have any cutouts or openings on the sides, which would make it look like less of a clean build.
If you have any interest in seeing some of my other projects - check out my channel: Franklinstein
Here's a list of the tools and supplies you'll need for this project:
Supplies:
- Double sided tape - https://amzn.to/3QqcP7B
- SNES cartridge - https://amzn.to/3OhlS8m
- M.2 SSD - https://amzn.to/44Vz9dJ
- USB-C right angle to bulkhead cable - https://amzn.to/3rJVwnF
- M.2 external enclosure - https://amzn.to/3KqZOqH
- #4-40 flat head screws - https://amzn.to/47o0uGW
- Foam tape - https://amzn.to/3KnIBhS
Tools:
- SNES screw adapter bits - https://amzn.to/3QjwgPl
- Screwdriver - https://amzn.to/3Oo8Eqq
- Hobby razor - https://amzn.to/3BCeSOn
- Dremel - https://amzn.to/3Oo8H5A
- Cutting blades - https://amzn.to/3zR6OrN
- Double sided tape - https://amzn.to/3OK1i1D
- 3d printer - https://amzn.to/3QbMc2Y
- Filament - https://amzn.to/3d3kRBN
- Scraper blade - https://amzn.to/44455v3
- Rubbing alcohol - https://amzn.to/44U9rWY
Step 1: Open Cartridge and Remove PCB
- Open the cartridge with these special adapter bits for SNES screws: https://amzn.to/3QjwgPl
- Remove the PCB
Step 2: Cut Internals on Cartridge
There are a few areas of the internal cartridge structure that will need to be removed to allow the SSD and adapter to fit inside. See image below for reference.
Step 3: 3D Print SSD Adapter and Other Parts
- Print the SSD adapter
- Print the adapter clamping straps (2x)
- Print the bulkhead adapter
- Tap the SSD adapter holes to #4-40
- Countersink the holes on the adapter clamping straps (not required, but looks cleaner)
- If you don't have a printer - you can print the files here
Step 4: Assembly
Let's put everything together!
- Add foam tape to one side of straps
- Apply double sided tape to underside of SSD adapter
- Insert SSD adapter into rear cartridge - press firmly to allow tape to adhere
- Insert SSD into adapter
- Install USB-C cable into SSD
- Bolt clamping straps on to hold it in place
- Bolt bulkhead adapter to bulkhead fitting of USB-C cable
- Apply double sided tape to bulkhead adapter
- Install bulkhead fitting as shown
- Reassemble upper half and screw everything back together - you're done!
Step 5: Design a Custom Game Sticker
One of my favorite parts of this project was designing a super custom label for my cartridge. You should do the same!
- Here is the template I started out with
- I used Canva to edit everything
- I printed my stickers with Avery labels
Step 6: Project Complete!
Now you can show off your super unique hard drive, with a custom game sticker.
Enjoy!
