Introduction: Super Secret Case, for Small Things
Ever needed a secret place to hold that, love note?, bullet?, coin? or anything similar?
Well, this is definitely what you need!
I mean, who ever checks the INSIDE of a lighter?!
Step 1: Gathering Materials.
Well, as you have probably figured out, we are going to be hinding our valuables inside a lighter.
When doing this instructable, don't be afraid to modify the lighter to suit your own needs, after all, it is D.I.Y!
Materials:
Glue Gun, or any other type of glue, tarzan grip etc
Jet Lighter, like the one shown, a bigger lighter is preffered, look for ones with lights or similar, usually they are bulkier.
Screw Driver and Needle, to remove screws and hinges.
Materials:
Step 2: Pulling It Apart.
Ok, so you have your brilliant New York lighter (guess where it's from?!?.)
Step 1:
On the bottom of the lighter, next to the refill nozle, there should be a small screw, undo it.
Step 2:
Pull on the top of the cap, to remove the 'lighter' from the case.
Step 3:
Remove the gas canister, igniter, and any other assorted electronics.
To remove the 'dodgy' hinges if you have them, poke one side with a needle of pin, then slide the metal out.
Step 4:
Where the flame is produced, lift the ring off, using a screwdriver. Pull the gas feeder out.
Step 1:
Step 2:
Step 3:
Step 4:
Step 3: Putting It Back
Righto, so we have our lighter in bits,
Step 1:
Get the pushy down bit, and glue it back into its original position.
Step 2:
Slide the cap, back into position.
Step 3:
Put your super secret things inside.
If searched, you mearly present them with a lighter :)
Have fun!
Step 1:
Step 2:
Step 3:
Have fun!
