Introduction: Super Simple Snoot
A snoot is a device which prevents the spill of light and/or the light source being seen from anywhere other than the target.
Snoots are used in theatre alot (also called top hats) and are used to prevent light spill and ensure that the only light seen is that reflected off the target, not that from the lamp itself.
Snoots are very useful in the bedroom to allow one to read while not disturbing the other occupants with "light pollution".
Step 1: Measure Twice Cut Once.
Equipment:
-Knife
-Cardboard (black and thick, flame retardant) DO NOT USE NORMAL CARDBOARD!!!
Alternatively black foil could be used which is obtainable from theatrical shops.....
-PVC tape (Flame retardant)
--Cheap halogen bedside lamp that spills way to much light
Measure the outside of the lamps head (pic 2) and ensure card is long enough.
A piece of A4 should be sufficient for most lamps.
Also measure any protrusions or knobbly bits
-Knife
Step 2: Cut and Roll
Cut out any protrusions that require cutting out and then roll the card to make life easier later
Step 3: Test and Fix
roll the card around the outside of the lamp so it is very snug, secure temporarily with paper clips.
Remove roll and use PVC tape to secure along the outside edge and in a little way inside
Step 4: Done and Tested?
Place tube ove light, ensure it is a nice snug fit. The tube should not require securing to the lamp if it has been made snug enough.
The Snoot can now stay on the lamp or just be slipped off if required.
Ensure the snoot is flame retardant and switch off lamps when not there. Beware fire danger from paper and lamps. Flambar is available from lots of cloth outlets if your require fire proofing.
In the entertainments industry these are generally made of metal, so if your feeling adventurous go with a metal tube, but ensure the inside is matt black!!!
