Super Sleek IPod or Other Device Video Projector
Intro: Super Sleek IPod or Other Device Video Projector
In this Instructable I will show you step to step how to Make a Super Sleek Video Projector for your iPod, Zen, Zune, DS, or Other Media or Gaming device. It Requires no Power to Function and you Do not Have to Disassemble your device; it will sit on a Basing above the Mirror.
STEP 1: Lets Get Fetching!
For this Project you will need to Find the Following Items:
>A Shoe Box
>A Sheet of Mirror (Preferably PVC or Acrylic)
>A Projector Lens (Slide Projector ones Work Well)
>Spare Cardboard
>Glue Sticks
And the Following tools:
>A Stanley Knife
>A Straight Edge
>A Ruler in MM
>A Marker Pen
Plus:
>A Basic Scale Drawing Ability.
NB: ALL MEASURING TASKS ON THIS PROJECT MUST BE PERFORMED USING A RULER FOR THIS TO WORK.
>A Shoe Box
>Spare Cardboard
>Glue Sticks
>A Stanley Knife
>A Straight Edge
>A Ruler in MM
>A Marker Pen
Plus:
STEP 2: Cut the Lens Barrel Hole
Firstly, Draw A Line from one Corner to the Opposite Corner on the other side.
E.G. Top Left to Bottom Right and Bottom Left to Top Right.
Where the lines Meet give you your Center. Measure the Radius of the inside of your Barrel and Cut your hole from the Center accordingly.
STEP 3: Marking the Mirror Angle
To do this you need to Firstly measure the Depth of your Box. My one was 12cm.
Next Draw A 12x12 cm Square
If you are on the left of your box draw from The Top right to the bottom left.
Then from the right draw from the Top Left to the bottom right.
On the inside you will need to draw the lines for positioning the mirror.
STEP 4: Cut the Screen Hole
1. Draw a Line 12cm from the top along the width of your box if your box is 12cm deep.
Depth = Line Distance from Top.
2. Draw a Line 4cm from the top of the box.
3. Draw a line 8cm from the top of your line drawn in step 1 as if to meet the line drawn in step 2.
4. Draw lines going from the left to right sides at the level of the lines Drawn in steps 2 and 3.
5. Work out the area of your screen on your device;
Formula:A=LB
=4cmx5cm
=20cm
Half your X and Y Axis values and mark a point for each and join the lines. Work from your center line and mark measuring half of each value on each side.
6. Then Stanley the Hole out neatly tidying the edges.
Formula:A=LB
=4cmx5cm
=20cm
STEP 5: Finalising
Measure your Diagonal line for your 45 Degrees and Mark This on an area or the mirror. Then measure the width of your box and join this to the Existing line on the mirror.
Get your Straight edge and put it along the line and score a couple of times with the Stanley, Continue this as Necessary then Snap the mirror out along the Lines.
Finally Put the Mirror into the Box with the edges along your pre-marked lines. When you are Happy with the Positioning simply glue gun the mirror in Place.
STEP 6: Showtime!
Put your device over the Hole in the top and position the Projector so that it has a Projection surface, Preferably a White Wall. Focus the Image by Rotating the lens on its Barrel Thread and Changing the Position of the Projector.
The images Below do Not do the Actual Projection much Justice, you would have to see for yourself the actual quality and brightness.
My Projector Can Project from a 1.5 Inch (Very Bright) to a 3 Foot (Watchable) image.
44 Comments
GameNox 13 years ago
BobS 15 years ago
zack247 13 years ago
DreadFred 14 years ago
deebs101 14 years ago
trlgal 15 years ago
z50j 15 years ago
Sytner 15 years ago
trlgal 15 years ago
Sytner 15 years ago
JellyWoo 15 years ago
Sytner 15 years ago
Sytner 15 years ago
Sytner 15 years ago
Sytner 15 years ago
Sytner 15 years ago
