Introduction: SurePunch Pro Punchdown Tool
Details:
SurePunch Pro Punchdown Tool with 110/66 Blade and Light terminates cable in single punch - including 23 AWG Cat6. Detachable LED light allows you to illuminate the panel work area in dark rooms.
Finger grips and non-slip rubber-embedded cushioned handle for comfort. It has a retractable multi-use spudger that can be used as a screwdriver or an IDC contact insertion tool. Hook to feed wires through holes.
Pick to separate bonded twisted-pair cables or to strip insulation and cut wireAdjustable HI/LO spring compression for all cable types. LO = 27.5 lbs (122 N); HI = 37.5 lbs (167 N)Uses twist-and-lock style bladesBlade storage area in end of handle with comfortable latch cover.
Step 1: SurePunch Pro Punchdown Tool
The SurePunch Pro Punchdown Tool comes with 110/66 Blade and Light. The SurePunch Pro Punchdown Tool is an impact punchdown tool that can use either 110 blades or 66 blades. With amazing features like the high and low impact settings, blade storage, and a LED clip light. The handle of this punch down tool has a built in wire probe to easily remove wires from a 66 block or patch panel that may have been punched down by mistake. The handle is ergonomically designed with rubber grips and also features a blade storage area in the back of the handle. The handle is two toned so you can always tell which side of the bit is the cut side. The LED light is a bright white and operates with replaceable alkaline button cell batteries; the light is easily clipped on and will not slide out once connected. Note: Greenlee recently changed this tool from Orange to Green. Shop online for computer networking supplies with your trusted source – cablesupply.com
