Introduction: Surface Graphics
This project is an exploration of maximized surface complexity. Each of the following 3 surfaces were developed in 3-dimensional space to have a high level of control in the form design of a thickened surface, then to puncture that surface design with conflicting geometry/holes so that the surface gains new planes of geometrical complexity. Basically, make it as busy, as heavy, as detailed as possible but to not lose control of the form. Bend it, don't break it.
These surfaces were jointly 3D modeled in Rhino and Maya to achieve the sequence of nurbs surface building, smoothing, and puncturing (booleaning); followed by geometric line extraction and projection for graphic representation.
PICTURED: Surface #1 Plan
Step 1: Surface #1 - Thickened
Beginning with poised wave patterning, this surface went from a naked edge nurb to a composed solid. The "bottom" face is not a replica offset of the "top". The dominant seams telegraph through the lower faces, but the design is individual. Sections were chosen at representative instances of complexity and pleasantness of shape.
PICTURED: Surface #1 Sections
Step 2: Surface #1 - Printed Segment
Powder printed portion of Surface #1 shows scalloping wave forms and edge treatment.
PICTURED: Surface #1 Powder Print, elevations, approximately 6"x11"x4"
Step 3: Surface #1 - Printed Segment
PICTURED: Surface #1 Powder Print, plan, approximately 6"x11"x4"
Step 4: Surface #2: Punctured
An array of perpendicular undulating pipes was designed parametrically then used to carve out from the first surface's solid form. In the first iteration, the piping is aligned with the z-axis, so the plan representation appears two-dimensional. When drawn in section, variation is more easily illustrated.
PICTURED: Surface #2 Plan
Step 5: Surface #2: Sections
PICTURED: Surface #2 Elevations
Step 6: Surface #2 - Printed Segment
Detailed image of holes puncturing the surface. A thicker segment of the surface was selected for printing to capture complex instances of the solid boolean operations.
PICTURED: Surface #2 Powder Print, detail, approximately 8"x8"x6"
Step 7: Surface #2 - Printed Segment
Step 8: Surface #3 - Graphic Plan
The graphic plan drawing illustrates the second iteration of holes in the surface in addition to the segment seams (dashed). This graphic plan serves as a diagram of the solid operations that yield complexity in the surface - and that are becoming too intricate to read clearly in the topographic plan.
PICTURED: Surface #3 Plan Diagram
Step 9: Surface #3 - Plan
Topographic information and transparent plan layers.
Step 10: Surface #3 - Sections
Holes in the surface are variable in size, depth, and axial orientation.
PICTURED: Surface #3 Sections
Step 11: Surface #3 - Fabricated
The model of the final surface iteration is constructed of CNC milled 25lb foam, post produced with sanding, joint compound, and paint.
PICTURED: Surface #3 CNC Milled Foam Model, 13"x20"x7"
Step 12: Surface #3 - Fabricated
