Introduction: Surrounding Brightness Remind Machine
About this machine:
If your surrounding is too dark which might harm your eyes, there will be sound to remind you.
- Arduino or Arduino Uno
- Breadboard
- Five wires
- Arduino Speaker (with wire)
Step 1: Build Up the Device
- Connect the photoresistor as the picture show
- the positive electrode (the longer end) to D Pin
- the negative electrode (the shorter end) to the resistor
- Connect a wire from the negative sign(-) to the GND, and another wire from the positive sign(+) to 5V.
- Connect the speaker with the device
- The black line connects to [GND]
- The red line connects to [~11]
Step 2: Copy the Code
Elements you can change:
- You can change the reference value of brightness
- The smaller the number, the darker the brightness
- You can change the key of sound the speaker play
- If you think the sound is too sharp, you may change it into another key
The link below: https://create.arduino.cc/editor/annika_lin/106a2...
Step 3: Make a Box
- Prepare a box or some cardboard
- Based on the size of your device, cut the box into a suitable size (My box has length 17cm, width 13 cm, height 8 cm. But however it is too deep for this device, an ideal height is approximately 3 to 5 cm)
- Start to dig holes
- You will have to dig 3 holes
- 1. A hole through which the wire can pass
- 2. A hole that show up the photoresistor
- 3. One to two holes to stable the speaker outside of the box (let the wire of the speaker went through the holes from the outside first, then connect them to [GND] and [11~])
The final product should look like what the video showed.
