Introduction: Survival Pocket Shotgun
WARNING: THIS INSTRUCTABLE WAS MADE FOR EDUCATIONAL PURPOSES. DO NOT POINT AT PEOPLE, ANIMALS, OR ANYTHING YOU DO NOT WISH TO BE DESTROYED. IF YOU HARM YOURSELF, YOUR FRIENDS, YOUR PETS, OR ANYTHING ELSE AND BREAK IT, IT IS NOT MY FAULT. MAKE THIS WEAPON AT YOUR OWN RISK! THIS IS DANGEROUS PEOPLE!
Now that I am done with my disclaimer, we can begin. This instructable will show you how to make a pocket shotgun. You will need:
1. emergency flare launcher
2. a 1 inch piece of 1/2 CPVC
3. a 4 inch piece of 1/2 CPVC
4. 1 1/2 CPVC coupler
5.  410 shotgun shells
Step 1: Step 2
Take the flare launcher, and hammer the 1 inch piece of CPVC onto the front end. Make sure it is flush with the end. Glue it on with some strong adhesive (JB weld or epoxy putty, you don't want this thing coming off).
Step 2: Step 3
Take the 4 inch piece of CPVC and push it into the coupler, then jb weld it.
Step 3: FIRE!!!
Take a 410 shotgun shell and put it into the coupler + 1/2 CPVC coupler. Pull back on the priming rod and then push it to the side until it locks. when you want to fire, hold with both hands, aim,  and push the priming rod to the side. This will send the priming rod forward, then the firing pin will hit the rear of the shotgun shell, set off the primer, ignite the gun powder, and the expanding gasses will send the bb's flying.
