Suspended Lighting
Intro: Suspended Lighting
This is a quick, cheap and simple suspended light setup using some light sockets and chain.
Most, if not all of the items you can find around your house / garage. I actually just went out and bought the materials I needed and was able to stay under $40.
BTW...This my first instructable, just something I threw together last minute.
Next time I'll try to get more pic's for the steps.
STEP 1: Material and Tools
- Wire Stripper / Cutter
- Electrical Tape
- Pliers
- Screwdriver
- Soldering iron / solder. (Optional)
- Hooks for ceiling. (Two or three needed.)
- (1) Extension cord. (I used 14ga)
- (1) Large loop chain, 10ft. (Got mine at Walmart for $10)
- (5) Non-switched light sockets. (Got mine at Lowes, $2.50ea)
- (5) Light bulbs of your choosing. (I used 60-watt Reveals)
STEP 2: Chain Setup
Cut the female end off of the extension cord and it's not needed.
Figure out the length of chain you need and where you want to mount the sockets. The chain links can easily be bent open to add or remove links.
I used 5 individual links to connect the sockets to the main chain.
NOTE; The chain shrinks once you put the extension through the chain due to the cord taking up slack in the chain. You may want to run the cord through the chain first while you measure what length you'd like. You can see how saggy my chain is without the cord in it.
STEP 3: Cord Prep / Wiring
Cord Prep.
- We will begin by cutting lengths of the extension cord. We need 4 lengths of cord to connect between the sockets. And we'll save what's left of the extension cord to connect at one end, for power.
- Cut your 4 lengths of cord and make sure to leave extra. I cut my at about 2.5ft.
- Strip all of the ends of the 4 cords.
- Start from one side. Take one of the cords and connect / wire it to the socket.
- Now take the other end of the cord and start running it through the chain to route it to the next socket.
- Now on this socket you are going to connect the cord you just ran as well as another cord. Each socket except for the the end socket have two cord (4 wires) connected to it.
- Take the second cord and begin routing through the chain to the next socket.
- This process is repeated until you reach you last socket.
- On the last socket you will just simple attach what's left of you extension cord. This is the piece that you'll be plugging into the wall.
STEP 4: Finishing Touches
Now we don't want any open electrical wires, so you'll want to either shrink wrap or electrical tape all the spots that connect to the socket.
On mine I just wrapped them with electrical tape. Kind of ugly up close but overall not to bad from far.
If it's budget permitting a fancy glass shade could be added around the bulb later on.
STEP 5: Done
Just hang and enjoy.
3 Comments
judeon.zhou 9 years ago
This cable hanging system is hanging by metal chain ,but there is some professional wire rope ,which is steel material ,very strong .
craig3 12 years ago
ChrysN 13 years ago
