Introduction: Multi-tool Keys - Mod / Hack
Modify your keys to fit in a leatherman. This is a real clever way to pack some spare keys around. You can fit up to six keys in one mini multi-tool.
Step 1: Materials
NOTE: Let me first state that I stumbled on this Idea browsing through the edcforums. There was a post a while back where user, shadeone had posted some pictures and a short tutorial on building one of these sweet little babies. Check out the original forums thread started by shadeone here. I take no credit for originating this idea, I've just documented my own experience building one. This is a modification to his original half micra design which allows me to keep the pliers and a few tools.
Also Stop by http://mathewmullen.com for more cool projects.
Materials
Leatherman Micra - ( I used a cheapo Husky clone that I got at home depot for $2)
Keys - (be sure to make copies of them first)
Drill
Something to cut the keys with - (I used a Dremel with a cutoff wheel.
Step 2: Disassemble the Multi Tool
Start by unscrewing and Disassembling the tool. Make sure you save all of the little parts and washers. Note that I was able to fit 3 keys per side so only undo one side if you are doing 3 keys or less.
Step 3: Select a Matchup Piece
Set one piece aside to use to match your key against when you are cutting it.
Step 4: Cut Your Keys
Cut down your keys to roughly match the end of the piece you picked in the previous step. You will be drilling a hole in them so be sure and leave as much meat as possible. You can fine tune it later.
Step 5: Mark and Drill the Holes
Place each key one at a time inside the tool in the direction you will be placing it and mark the hole with a fine point marker through the hole in the tool. I placed mine teeth down so it is easier to pull them out by hooking a fingernail in the grooves across the top.
Once you have marked all keys, mark your starting points with a punch or nail and drill your holes. The size of the hole may vary depending on what kind of multi tool you choose. Start small as you can always bore it out more if necessary.
Step 6: Put It Back Together
Re-assemble the tool substituting the keys for the tools. Be careful of three things. 1) Be sure you put a washer in between any metal-on-metal contact. 2) Make sure you place the keyring attachment piece somewhere where it will not interfere with a key. 3) Most importantly, remember to leave a gap in the middle of each side for the pliers/cutters to fit into when you collapse the tool. ( I placed two keys all the way to one side, then a bunch of washers and then a key against the other side.
One little tip: If there is a skinny leather punch or mini screw driver piece, you can stick this through the hole when re-assembling the tool to help keep the washers and the pin in place. This also worked well to wiggle around to get everyting to fit together properly.
I was thinking for my next attempt to use a slightly wider, folding style alan wrench set and try to get a bunch on each side.
-Pyro222
161 Comments
14 years ago on Introduction
This thing is gonna get me killed by a highway patrolman someday.
LOL
OMG! My father is actually a policeman and we laughed a lot once I showed him this. It will be so cool to post this as the Best Multitool for your car! We can't stop laughing! Thanks for sharing Speckone!
Reply 13 years ago on Introduction
Lol, that image has made my day
Cops: have you stolen this car and rammed a mulitool into the ingnition switch?
me: *removes key* No officer, *procedes to open multitool to show off the other keys*
Cops: *pulls hand gun* Put down the weapon, exit the vehicle and put your hands on our back!
lol again.
hahahahahahahhAHA lol man good 1
Reply 14 years ago on Introduction
dude, my mom, and dads car uses the chip in the key, I wanted to give them one for Christmas.
you can bring it to the store and have them fit a normal key for around 9 bucks
If you try to use a regular key in a vehicle that requires a chip key, it will actually lock out vehicle use on the internal computer. You HAVE to get the EXACT key from an auto retailer, or online, otherwise you will go through a great deal of trouble and money.
looks like you just hotwired that car
Bahaha dude thats awesome.
hahaha Nice instructable but is pretty heavy so it may screw up your key switch and they are annoying as hell to replace.
hey... is that... MY car??? :D
i'm planning on making one of these
hahaha. Yeah, that doesn't look suspicious at all. Very Cool!
Haha, that is hilarious! Nice one!
hahahahaha
8 years ago
This is the most practical thing I've ever seen on instructables
Wow that awesome, so detailed info and thats a great idea also! I just discovered this site and I am amazed! Regards, Dianne from bestar15scope.org
Amazed at your patience in this review.
Dissembling and putting it back together, I can only imagine the time
needed just for this post.
I've worked in a multitool factory for
years, and this might not be the best multi tool out there, but the
thoughts in the comments and the article itself really made my day.
This can double as the Best EDC Knife. It will be cool to have this type of key for your car, but at the same time use the same key as a good blade. :)
Maybe this will be coming soon. :)
