Sword of Megatron Made From PVC
Intro: Sword of Megatron Made From PVC
Hay guys this time I will explain you how I made any an iconic weapon from the movie transformer.The weapon I made is a sword used by Megatron.I decided to make this particular weapon because of its simplicity.its nothing but a fancy sword and you don't need to have any power tools.I used only PVC to make the sword.this was my first attempt to make something using PVC but I have seen a previous instructable which explains how to make a robot fish using PVC so that instructable inspired me to do this one.PVC is very easy to get and I am only using leftover pieces to make the sword.We don't need long or particular sized pieces for this project do its very easy to get all required materials.we also need pvc cement and cutting tools sand paper for this picture 1 shows all different sections of a sword take a look at this picture before reading below steps.picture 4 is only half scale drawing of the original model all other drawings are same size as the sword
STEP 1: Making Blade
STEP 2: Making Flared Tip
STEP 3: Connecting Parts
Its time to Glu the seperate pieces together but the Glu alone was not strong enough to hold it together.There was no much surface area in between Pieces to add glue so I used thin nails and Glu for this purpose.Arrange all the pieces correctly and take two nearby pieces and make two holes in-between the layer(see pictures)use the same nail for making holes and don't make it too big because it should be a tight fit.then Mark the exact position on the next piece and make holes do this on all pieces.cut the nails to suitable size and put it in holes with some superglue and stick it to the next piece,there will be a small gap but we can clear it later.c connect all pieces similarly.
STEP 4: Second Layer
Once all parts are connected it's time to add the second layer(black).this layer is made of black plastic pipe but since there was no need of bigger panels I didn't cut open the pipe insted I heated the pipe and flatened it. this way I got thicker flat piece.I made four 11cm long piece for the Blade part.this one is slightly longer than the Blade so when connecting the end piece to this we can use the extended portion to screw the Flared tip.another piece is made similarly using same material(picture is given). these pieces are glued over the assembled tip.one more black piece is cut in to shape for the end part this one is fixed perpendicular to the blade use nails to fix it as we did earlier and finally we need 24 small black tips to stick along the Blade .I glued six on each side sepperated equal distance.repeat the same step on the other side also this black layer apart from aesthetic provides strength to the Blade and hold all pieces together.
STEP 5: Making Hilt
STEP 6: Finishing Tuches
After all parts are attached there will be some gapes between layers and parts to cover this I used tile filling its very cheap nd available in almost all shades I used black and white powder for this one.i tried using white cement initially but it tends to crack and fall of once dried.this tile filling wont crack and can easily be used to smoothly finish the gapes. Add 30 percentage water to it and fill the gapes once dried use a sand paper to remove the excess material.use the same to clear any miss cuts or deformations. After attaching the Hilt to the Blade use a PVC panel to hide all the mess(see third picture)Once the tile filling is dried you can paint it I applied two cots of paint on the white part so it seems like a single piece instead of many smaller part also painting would hide all tile filling.after the paint is dried I used a sand paper to remove and smooth the sharpened places.i dident paint the black part but sanded it to give rough look.i painted the black tips on the Blade except the very end of it only because I was not happy about the looks.i dident do anything to the grip and pommel.Using a sand paper remove the paint from the sharp parts of the Blade.
My finished sword is 1 meter long and its strong enough to give couple of swings,but its not sharp to cut anything.in future update I will paint it with some metal colour.
Now try making one of your own may be a different design or size.Its very easy if you have a rotary Carver or something similar.
PVC Robot fish Have a look if you are interested
