Introduction: T-Rex Skull Carved From Ancient Wood
I spent 400 hours carving a T-Rex skull out of Old Growth Redwood Burl.
Step 1:
I purchased this amazing MASSIVE piece of Old Growth Redwood Burl. I sketched on my design and worked with the natural wood shape to maximize the size of the skull.
Step 2:
I cut the burl into more workable pieces while also squaring up the sides to help with my carving process.
Step 3:
I used templates of a T-Rex skull to draw on and basically use the chainsaw to just cut closer and closer to my lines.
Step 4:
This was about a week into the carving and you can see it is starting to take shape, however there is still a LOT to uncover.
Step 5:
Further along in the process I began to carve out the inside. This was the most challenging parts of the entire build, as no tools I had could get into the angles. What should have taken only a couple days ended up taking a full week because I had to remove material so slowly.
Step 6:
Time for the teeth! The largest tooth I carved was over 5" long. I selected the most beautiful pieces of wood to use for the teeth. Each tooth was carved, sanded and implanted into the skull. I then used wood glue mixed with sawdust to hide all of the gaps.
Step 7:
I sanded this piece for 2 weeks. Sanding the inside portion of this skull was very time consuming. I had to sand 95% of this piece by hand.
Step 8:
I made a one of a kind pedestal. Solid Oak dyed black with brass accents. The pedestal has a raised platform for the lower jaw to rest on with magnets. It also has LED lights inside that light up the inside of the skull.
Step 9:
Its done! Be sure to check out the entire build over on my youtube channel @BMsculptures. This sculpture is also listed for sale on my website.
