Introduction: T-shirt Designs With Stencils and Bleach (updated With Robot Image for Download)
Make your own awesome t-shirt designs using stencils and a simple solution of bleach and water.
This project requires minimal tools, and it comes together fairly easily.
**update**
The robot stencil shown is now available for download
Enough talk, let's get started!
**update**
Step 1: Gather Materials
Here's what I used for this shirt (really you can use just about anything for the stencil):
- Sharp hobby knife
- Sheets of cardboard (flattened cardboard boxes work well)
- Spray bottle (got mine from the Dollar Store, though they charged $1.67, what a crock!)
- Bleach (again Dollar Dollar, but was more. Seriously guys, change your name)
- A fun shape (any object will work so long as its silhouette is easily recognizable)
- Plain t-shirts
Mix the bleach and water 50/50, you're going to need a bit so I'd recommend a minimum of 250ml (1 cup) of each. Now is a good time to wash your shirts to get the shrinking out of the way.
- Sharp hobby knife
- Plain t-shirts
Step 2: Design
Do some homework, figure out what images work, and which ones don't. You can use something from a magazine like people, or maybe something from the internet. Again we are looking for simple shapes that are easily recognizable in silhouette. An easy way to check is to cut out your image and flip it over, if you can still make out what it is without seeing the internal detail you're golden!
For this shirt I used a blue whale I found on the www.
Step 3: Cut It Out!
Yup it's time to play with knives! So once you've cut out your image, you can stick hum to the cardboard and cut it out, or trace and then cut. If you're feeling super creative why not try drawing directly on the cardboard then cut it out.
A word of caution is not to make the shapes too detailed, as this method tends to let the bleach bleed a little and fine detail will not show up.
Step 4: More Cutting
So for this shirt we are going with a whale in the ocean, no aside from the whale I'm going to need something that looks like a waterline for the ocean.
Step 5: Prep Work
Find a well ventilated area to do your spraying in. I'd suggest the garage, or some place outside. Remember folks, you're spraying bleach onto fabric, so doing this on your nice new rug isn't such a hot idea.
Place a sheet of cardboard inside the shirt to stop the bleach from stenciling the image on the other side.
Step 6: The Fun Part!
Composite your cut outs as you want them on your shirt. For this image I chose to do the wave portion first, then placed the negative cut out of the whale afterwards. This is a little more complex than just one spray, but it looks good.
Wait until the fabric starts to turn the colour intensity that you desire, then quickly rinse the shirt thoroughly to stop the bleaching process and remove any excess.
Step 7: Finished!
Your t-shirt is now done!
Wash again to remove that awesome bleach smell, and you're ready to show off your new shirt to your friends down at the library, falconeering enthusiast club, or just wear it around the lab.
I decided to embelish these guys a little more. The one on the left is done with fabic paint applied with a brush, and the one on the right has fabic squares sewed to it with fabric paint directly applied to the squares.
Step 8: Some Final Thoughts
Now you're ready to show off your neat-o new custom t-shirts! You're sure to be the talk of where ever you go!
Remember to make sure your designs are not too intricate so your bleach spray doesn't bleed and ruin the crisp edges of your design.
Pros of this method: Fading effect, and some crisp edges where the spray meets the card.
Cons of this method: Potential for the bleach to bleed under the card, so be careful.
**update**- September 6, 2010
Uploaded the robot image, feel free to download the PDF and make your own!
