T-shirt to Sexy Top
Intro: T-shirt to Sexy Top
How to transform a boring old t-shirt into something that could make you the star of the party: turn it upside down & create some fancy pockets.
STEP 1: Things You Will Need
1. Any old t-shirt, large enough to fit you. It is preferable to use a t-shirt that doesn't have big prints or things written on it, as you will turn it upside down.
2. Scissors
3. A sewing machine (or sew it by hand)
4. Safety pins
5. Elastic (about 1,5m)
STEP 2: The Lower Part
Measure the circumference of your chest.
Cut a piece of elastic that matches your measurements.
Turn the shirt inside out and cut a small opening on the bottom hem.
Use a safety pin to attach one end of the elastic and insert the pin through the small opening. Pass the safety pin (and the elastic) inside the hem until you reach the other end.
Attach the two ends of the elastic by sewing them.
Turn the shirt right side out. Now it should look like the picture.
STEP 3: The Upper Part
We'll now look at the upper part of the shirt.
Use some pins to hold the fabric still.
Cut all excess fabric so in the end you'll have a straight line at the top. Make sure you cut any visible part of the collar.
Use some pins to attach the sleeves at the front of the t-shirt in this particular position (arms crossed). You will sew them on the shirt later.
Use the sewing machine to make a hem where you cut the excess fabric.
STEP 4: The Pockets
Turn the shirt inside out.
Sew the sleeves to close their opening to the rest of the t-shirt. Turn back the shirt right side out.
Cut two small slits on the hem of one sleeve, at the inside: each slit should be at one end of the sleeve when it's folded.
Cut a piece of elastic that is shorter than the width of the sleeve.
Pass the elastic through the sleeve's hem using a safety pin. Sew the ends of the elastic to the fabric.
Repeat on the other sleeve.
Now you are ready to attach the sleeves to the t-shirt.
STEP 5: Wear It!
Basically, you'll wear your old t-shirt upside down. Depending on the size of your shirt, your result could be worn as a top or a dress.The outside pockets make a nice addition, but you can also attach them to the inside of the shirt, for a simpler outfit.
81 Comments
upcycledstylegirl 8 years ago
Can't WAIT to make one!!! I'm large busted and I get so tired of not being able to sport a tube top!!!
VickieR 9 years ago
This is so Awesome!!! I can't wait to try it!
KattieP 9 years ago
<a href="http://magazinebankinfo.blogspot.com/">Click Here For More Information</a>
gmushroom 12 years ago
Signature
MaryJIEL
blood pressure device offered by PulseStore
pniler 12 years ago
tstan13 12 years ago
lushluxelovely 12 years ago
http://lushluxelovely.blogspot.com/
ttjong ayong 12 years ago
hahahippo=) 12 years ago
dhill9 12 years ago
http://www.culturallycool.com
fpa1 13 years ago
platinum15 13 years ago
grooooovy 13 years ago
isavendetta 14 years ago
im already making it!! it's awesome how easy and cool is it!! thanks a lot for making it so easy! and stylish!
frenzy 13 years ago
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
https://www.instructables.com/community/I-Made-It-Challenge-Is-Back-Win-A-Pro-Membership/
susanrm 13 years ago
isavendetta 13 years ago
njn 13 years ago
uniqueleigh 13 years ago
