T962A SMD Reflow Oven Fix/Hack
86,353
57
48
Introduction: T962A SMD Reflow Oven Fix/Hack
I've recently purchased a popular T962A SMD reflow oven. The reviews are split on this oven - some find it to be quite acceptable, while others find it completely useless. After much researching, I decided to give it a try.
(Feel free to skip this part if you already have the oven.)
T962A is an inexpensive IR (infrared) SMD reflow oven. It has a microcontroller to control temperature and timing (profile), so you can basically put populated PCBs in, push the button and simply wait for a few minutes. Then the PCBs are done.
There are some issues with this oven, but my experience is rather positive overall. For my purpose this oven works well.
However the problems are:
1. The oven produces horrendous smell.
I'm not taking about the smell of solder paste melting. The oven itself produces the smell even without anything in it.
2. The heat distribution is not very even.
This is not an issue with leaded solder, but becomes a major problem with lead-free solder. As lead-free solder requires much higher temperature to reflow, the extra temperature needed to ensure the solder reflow on all parts of PCBs can burn the parts in the hot spots. Even though I'm lucky enough to not fry any PCBs with this oven, some parts did come out looking burned.
I want to share what I did to improve on those issues.
Step 1: Why So Smelly?
Like any oven, I expected some odor/fume to come out on the first few runs. But this oven is no ordinary oven in that respect.
Upon its first run, it produced something that I have never smelled before. It was so toxic, that it gave me a bad headache. And the smell did not go away even after a few runs.
So I decided to open it up and see what's causing the odor.
Opening the hood was quite simple, just pull the drawer out, and remove a few screws. Then the top is open.
Then there was the source of the problem - masking tape! Masking tape is used to prevent electrical shorts between the aluminum foil used to cover the insulation material and the controller PCBs. Even though there's heat insulation material beneath it, the tape gets hot enough to produce that nasty odor. So I removed all of the masking tape, and replaced it with Kapton tape, which is heat resistant.
(Sorry I forgot to take the picture of the masking tape before removal. You can see some pics here though.)
This mod took care of the odor completely.
Step 2: Improve the Heat Distribution
Infrared reflow oven has an inherent weakness - because the infrared heat is absorbed at different rates depending on the surface color, black ICs get heated up quickly, yet metal parts heat up slowly. Temperature profiles are used to give some "soak" time to let the temperature even out between different parts of the PCB. However that can only help so much.
Modern reflow ovens mostly use convection technology. Convection ovens use moving air to deliver the heat. This method distributes heat much more evenly then IR method.
T962A has a cooling fan in the back. This fan sucks air into the oven to cool down the inside. The heated air comes out of the bottom of the oven, which has many slots.
So I thought, why not use this fan to give some air movements during the heat up, to help distribute the heat?
Looking at the controller closely, it is revealed that:
- Heating elements are controlled by a SSR (Solid State Relay) via 5 V logic voltage from the controller.
- Fan is control in the similar mannor - logic signal controlling a triac via an opt-coupler.
I connected four wires to get the necessary I/O out of the controller board. and routed the wires out. Connecting the switch to the fan controller line proved that it works.
(If you are doing this please see comments on the photos - there are some importent information in there.)
Arduino to the Rescue
Now I got the signal that tells me whether the heater is on, and a line that lets me turn on the fan when I want. I believe by blowing just the right amount of air when the heater is on would improve the heat distribution. So I took out my Arduino, and wrote up a simple code. The code basically senses if the heater is on, and if it's on runs the fan at a low speed. To run the fan at a low speed, I chose to do super low frequency PWM, which ended up being turning on the fan for 0.1 to 0.2 seconds, and turn off for 0.8 - 0.9 seconds. I did it this way instead of using Arduino's PWM output, because the fan controller may not respond well to the signal going on/off hundreds of times a second. I'm using 15% duty cycle to run the fan.
By running the fan slowly enough, the hot air inside is moved around to help distribute the heat. The heater is strong enough to still heat up quickly.
The result is an improved heat distribution, and seemingly more accurate temperature reading. I think the air movement helps the thermocouple (temperature sensor) inside the oven to sense the air temperature.
More testing and tweaking might be needed to get the most out of this modified oven. But so far I'm very happy with this.
3 People Made This Project!
- FredWalks made it!
- chinmay.das made it!
- colorado_rob made it!
48 Comments
Question 2 years ago
I have yet to find any T962A at a reasonable price. I am seeing the T962 at about $200 usd and just bought one. I am wondering what mods are needed for it. I know it is only 800 watts compared to the 1300 watt T962A but besides being smaller and drawing less power what has to be done to them in the way of mods? I understand the Firmware flash and suspect the masking tape but beyond that what should be done to the T962's?
Thank you.
Where do you find the T962 or T962A at a reasonable price? I am seeing them at $300 usd and up. I am wondering if getting the Controleo3 controller and a kitchen toaster oven would be just as good since the T962 and T962A have not had the best reputation.
Answer 2 years ago
Recently ordered a T962 here in UK for less than £140 - now awaiting delivery. First thing to do is the replace the stinking masking tape and make good proper earthing of the unit.
Many improvements have been carried out to make the performance acceptable. Have a look at "https://github.com/UnifiedEngineering/T-962-improvements/wiki" to see the low down on modifications to both H/W and S/W. More information and discussions are at "https://hackaday.com/2014/11/27/improving-the-t-962-reflow-oven/".
Answer 2 years ago
I checked and the price seems to be around $350 or less for T962A nowadays. I payed more and think that it's totally worth the money for me. (I was reflowing at least once a week for small batch production.) But if you only occasionally reflow solder, you might want to go with a toaster route. However I personally have seen pretty bad result from a hacked toaster around me and just don't think it's worth the hassle. It really depends on your needs.
Reply 2 years ago
"But if you only occasionally reflow solder, you might want to go with a
hacked toaster around me and just don't think it's worth the hassle"
That is part of the reason I was looking at this Instructable. Google is not much help searching for DIY Toaster reflow oven and the few it returns are very very old. OSHPark has a few shared boards but it is hard to find the actual project for the board and the BOM for them and when I do find the project page I find as you mentioned that the hack is a waste of money. I have looked for email forums on the subject but have not found any yet. I am tempted to go with the Controleo3 but not sure if I need the basic $109 package, the $249 package, or the $299 package and which oven do I get? Conventional? Or Convection? I was tempted to go with the T962 and someone on one list had an ebay link to one for buy now at $129 but would not ship to USA.
3 years ago
Just got mine, and replaced the masking tape as suggested. Thanks very much for posting this!
3 years ago
The beeper in the T962A is horrible, in that it beeps continuously at the end of the cycle. If you want to fix that, I am selling a little board on my Amazon page. Search for T962A beeper hack on Amazon. I made it for me, then put it on Amazon just to see if there is any interest. I can make more if the first ones sell out. If anyone wants to have the schematic and/or layout files, it's in Kicad so just ask.
5 years ago
Thanks for this. I saw it pre-purchase, and it made me comfortable enough to buy. I'm surprised that in 2 years they have not addressed the masking tape issue. Must be tight margins.
Opening, removal of masking tape and replacement with caption tape, and reassembly worked like a charm. Front screws were a bit fussy... they are stripped-ish. Reassembled well. First fire-up - still pretty smelly.
I'll do another run and see how it goes..
5 years ago
Kapton tape worked like a charm. I didn't smell anything nasty when I fired up the oven for the first time. Maybe I'll try the fan controller next -- but you know what would be kinda cool? A light.
6 years ago
I did your improvements on the oven with the exception that I cut the connection from the fan - line, put the one side to an other input of the arduino and an other output from the arduino to drive the fan, as you did. In the software I did also the check, that if the heat is off, and the fan is on, I switch on the fan constantly
Now I did two measurements, first I put a PCB in with a underlay of about 6mm. On this pcb I put a temperature probe. During the process I also took time and compared with the time of T962. I realized two points:
1st: the temperature on the display is about 20 - 30 Kelvin below the measured temperature on the board. That means, at a display temp of 160°C I had about 180 - 190°C on the board. The higher the temp, the smaller the diffrence. At about 250°C, the board temp was about 265°C.
2nd: the time for the process took on the display 8mins. I took a time of 12minutes which is 1.5 times more!!
At the company where I work, we have a Protoflow E reflow oven from LPKF. We have really good results with lead free soldering. I put in that soldering curve, which gave us really good results....
First heating up to 160°, holding the temp, than put in the PCB and as the temperature reaches again 160°, it pre-heats the pcb of at this temp for about 160seconds. Than it goes up to 260° during 100seconds, that means a ramp of 6K per 10 seconds. At 250°C we need to open the door at the LPKF, but the origin curve goes than down with a ramp of 10K per 10 seconds.
About the much higher temperature: Has anybody made the same experiences that this temperature is this higher than the displayed? If this is really ture, I need to take down the whole diagram of about 20K. And about the time, I need to shorten the whole time range at factor 0.66.
This to much of temperature might be THE reason why so many people get burnt components during lead free soldering with curve 3. I have tried this curve, had also burnt components and bad solderings.....
7 years ago on Step 2
I just bought one of these ovens. I'm sure glad that that you wrote this up
7 years ago on Introduction
I would like to know why if you have firmware for the unit you also need an arduno to control the fan. seems to me if you have working source code you can just pwm the fan as you see fit.
I just bought an oven and got it today and am thinking about doing a full schematic on the controller board.
7 years ago
The controller project is hosted here: https://github.com/UnifiedEngineering/T-962-improvements
https://github.com/UnifiedEngineering/T-962-improv...
This should be a link now. It wasn't entirely obvious to me that it wouldn't automatically turn the URL into a link when posting from my mobile device earlier.
Reply 7 years ago
My alternate firmware project that is.
That looks very impressive. I will check into it. Thank you very much for sharing!
Reply 7 years ago
I got inspired by your Kapton tape mod and got carried away a bit so I wanted to share my findings here.. :) At least it will show people how the hardware is wired to the controller MCU. Everything but the buzzer is operational (and the buzzer is a simple known gpio pin)
Thanks very much for this tutorial. Was good tech review before I bought one, just saved me to make the entire house smell bad for that useless masking tape. Anyway I made your mod with the Arduino, works fine definitely the temp in the oven is more even across the surface. However my oven still burns PCB's!. The issue is more likely to be caused by timing, as varying the reflow graph I get different outcomes ( sometimes burned, sometimes solder did't melt). I first tried to change the crystal as hoping that will fix the issue, (originally has 11mhz mounted on) 12mhz improves but not enough, 14mhz the display will not display characters properly. At the end I gave up with the idea of fixing the timing, and went back trying creating a new reflow graph including the time offset. So far no luck in creating an ideal graph for Leaded 63Sn/37Pb paste, with this oven. There is any chance that you can share with us your adapted reflow graph, showing time Vs Temp, that will be really helpful.
The T962-A is a such good oven, is a shame that they made a mess with the software. I noticed that the board as all the capabilities to drive that oven properly, and luckily there is an ISP connector for programming. I hope that maybe one day someone will create an updated firmware for it...
Reply 7 years ago
I've put some effort into an alternative firmware for the LPC MCU present in the original controller. I have also enabled the fan to run during the reflow cycle, and it definitely helps as long as it doesn't run too fast. Reaching peak lead-free reflow temperature is challenging when fan runs faster than minimal speed.
Reply 7 years ago
Great someone finally put the effort in doing that. Did you solve the timing issue? I think that the best way to solve the problem of no airflow, is to add an internal fan (as conventional cooking ovens). Any chance you can share the firmware with us?
