Introduction: TABLE SAW LONG PIECE CUTTING JIG
I have a Unisaw with a 52" fence. Needless to say, cutting a forty-five on 3/4" stock longer than its capabilities is a challenge.
I could run against a sacrificial fence, but that requires me to rely on the cut portion, in back of the blade, to keep the cut straight. Experience, more likely than not, will tell you the piece will shift and give a less than perfect cut.
I was working a piece of flat stock 36" wide by 60" long. I had to put 45's on the 36" ends.
I could have built a sled, but it would have been huge. Instead, I made an absurdly simple jig, which relies on the miter slot and the piece being cut to perform the task.
To solve the problem, I built a jig, which rides the miter slot of the table saw and allows me to get past the limitations of the length of my table extensions.
Step 1: USING THE JIG
1) Drop the jig in the miter slot; 2) Slide the stock into the jig and, with it pressed against the fence, lock it in the jig; 3) Move the fence well back from the blade. Regardless of the cut, the fence is only used for setup; 4) Slide the stock back from the blade; 5) Raise the blade; 6) Turn the table saw on; 7) Run the stock using the miter guide and rail to guide it. NOTE: When positioning my jig guide rails, I like to leave a little bit of the rail sticking out the front of my jigs, so they start tracking the miter slot before the wood contacts the blade.
Step 2: SETTING UP THE JIG
This set up is the one I used for cutting forty-five degree cuts on the end of an already squared piece of stock. The jig can also be used for cutting pieces not already cut to size. In those situations you would adjust the position of your fence away from the blade according to need.
When in use, the jig clamps to the piece being cut and forces it to follow the path of the miter track. How closely it follows depends on how tightly your guide bar rides in the track.
To set the jig up for the cut:
1) Set the blade to forty-five degrees;
2) Set the fence to zero (so the blade is just touching the fence);
3) Drop the blade below the table.
Step 3: CONSTRUCTING THE JIG
The jig can be constructed from wood, aluminum, iron or a combination of any of those things. At the least, a hard wood should be used for the rail that follows the miter track.
I keep 3/8" aluminum flat stock on hand and cut it into rails for jigs that rely on the miter slots of my band saw, table saw, or sanders. Since cutting aluminum on a table saw is not the most fun I've had, I try to cut extras, when cutting a rail. As such, I had one 3/8"x3/4"x48" rail already cut, so I used it for the guide rail, which will ride the table saw miter slot. For the top, I just used a strip of poplar I had in my odds-and-ends collection.
I drilled holes about three inches apart and just big enough to allow me to thread them to take 1/4 x 20 screws. I didn't bother with the six or so inches to the left and right of center, since cuts that small could be done on my miter, and narrow pieces would be better done on a sled.
Once the holes were threaded, I counter sunk the side that will ride on the miter track. This allowed me to run 1/4 x 20 flat head screw flush with the bottom of the jig, to avoid having the screws hang up going in the miter slot, or holding the material up, off of the table.
I used a piece of poplar for the top. I cut it to the same length as the aluminum bar, but left it at about 1-1/2" wide and 1" thick, since its dimensions were not as critical as the guide bar.
I drilled holes in the poplar that matched the holes in the aluminum stock. This allows it to drop down over the screws mounted in the guide bar. The different holes allow me to move the screws closer together or farther apart to accommodate different wood dimensions. For example, my project required me to use two holes about forty inches apart, to hold a pieces of plywood five feet long and three feet wide. I used 3" long 1/4" x 20 (threads per inch [TPI]) flat head screws, mounted from the underside of the bottom rail (previously countersunk).
With the screws in position for the piece I was cutting, I installed the top piece and two locking knobs.
![Simple DIY Workmate [and Bench] Hold Down Clamps](https://content.instructables.com/F30/2VOI/MCKVOZ2C/F302VOIMCKVOZ2C.jpg?auto=webp&crop=1%3A1&frame=1&width=130)
