Introduction: THE ESSENTIAL POWER SUPPLY
Hey guys
So you're just starting electronics or have been a hobbiest for a while now.
A power supply is a must for, so in this instructable I am going to show you how we can make a very basic and easy to use power supply for practically nothing.
The power supply can deliver upto 20 volts at 3 amps and is more than enough for most tasks and with the way we are dependent on our smartphones (or USB devices in general) I decided to add an USB power supply that can be used to charge your phone (completely optional though I just used it for my convenience)
In a previous instructable I had shown you how you could build a power supply which had a couple of fixed voltages and a variable one. Though the build was a little more complex I hadn’t included a high power output option thus making it useless for a variety of applications. After sizing up all options I have figured a good, viable and most importantly easy to build (ie beginner friendly) power supply.
PLEASE TAKE A MINUTE AND VOTE FOR ME
So without further ado, let’s get right into
Step 1: Materials and Tools
You would require the following parts to build the power
supply
1. Old laptop charger (the heart of the build…you can use any other power supply also but laptop chargers are generally compact and can deliver enough power also.)
2. Voltage regulator – I have used a lm2596((buy here) as if deliver up to 3 amps ) based voltage regulator module but you can use an lm317((buy here)which can be made easily and I will explain it in a further step) but I don’t recommend using a voltage divider(it being very inefficient)
3. A enclosure to make the build look good – I used an old watch box but one can use anything from cardboard to custom CNC box.
4. A switch - make sure it can handle the power coming out of the power supply
5. A panel mount voltmeter (buy here)though this is extra and not required it adds a lot of convenience
6. Alligator clips – completely optional
7. Banana clips to make a swapable connection point- I didn’t use them though
8. A 5v AC to DC step down with a USB port to charge up your electronics OR a 7805 DC-DC step down converter to power the voltmeter.
9. Potentiometer with a knob would be good
10. Wires
The tools you will require apart from the basics like a screwdriver are
1. Soldering iron (with solder)
2. Dremel or any other rotary tool –optional
3. Multimeter-optional
4. Drill-optional
5.Hot glue gun
6. Tape
an hour or two depending on your experience and how elaborate you make the build
Step 2: GET RID OF THE EXCESS PLASTIC
Most probably your laptop charger would be covered in thick plastic which is useless as we would be enclosing the whole thing in an enclosure.
This step can be very dangerous as we would be dealing with exposed connections and should be performed only when the power is off ie the charger is not connected.
Though this isn't necessary but you can start out with a dremel or a hot knife and slice the plastic where they appear to meet.
Next you would see a few more layers of plastic and a layer of metal which is earthed which can be left as it is.
Now is a good time to connect the AC input of the 5v wall vort to the AC input of the adapter or if you are using a 7805 you can hook it up to the DC output of the laptop charger now(according to diagram given in the pics.)
Step 3: WIRING THE VOLTMETER
So the voltmeter has 3 wires
RED- the power wire which gets connected to the positive terminal of the 5v supply
BLACK- ground and gets connected to the negetive of the 5v or the common ground
WHITE- the sense wire which gets connected to the output of the supply...LATER
after giving the voltmeter power the display should light up.
Step 4: THE VOLTAGE REGULTOR
If you have chosen to make a regulator with a LM317 then i have included a schematic diagram or if you have bought one then make the following connections
The input has to be connected to the output of the laptop charger
If you have bought a voltage regulator then there would be a potentiometer on the board itself which can be replaced by potentiometer (shown in the materials step) with wires for extending it.
Step 5: FINISHING UP
Place all the parts in the enclosure in a compact way and drill in holes for the switch and the pot and make a hole for the voltmeter.
if you want to add a switch add it between the negative output of the laptop charger and the voltmeter as shown in the diagram.This way the voltage regulator part switches off but the USB functionality still remains on.
Give the whole thing a coat of paint and voila its done.
Any queries in the comments thanks for reading do follow me for more such builds.
Third Prize in the
Power Supply Contest
Explore Science Contest 2017
Invention Challenge 2017
7 Comments
5 years ago
Great !! Have a look over my instructable
https://www.instructables.com/id/Worlds-Smallest-DIY-Pocket-Power-Supply/
Reply 5 years ago
Really good dude... I wish i also had a 3d printer
Reply 5 years ago
Thanks for the compliment but your project is also very good and neatly build
5 years ago
Nice. Why not connect the 5 Volt Voltage Regulator to the output of the Laptop Charger? You then do not need a step-down converter.
Reply 5 years ago
yes rob thats what i have tried too say either you can have a 5 v regulator or the 220 to 5v step down converter.
it is an option to choose from and i chose the latter one as it added a usb port for me to charge my phone.
5 years ago
Though I "claim" that I could make a better case for this power supply, what you outline here is a simple way to make a power supply using cheap parts that requires not much more than a lick of electronics knowledge. And although I have long considered making a power supply in this exact manner, you indeed make the guide for it, and even gave a circuit diagram. Props to Paurush, good work.
Reply 5 years ago
Thanks pandadude
