Introduction: TJ-SR-V4
About: Figured it was high time to give this a quick edit. I was an active part of the K'Nex community from about '08, I still occasionally lurk. I did a lot of dumb stuff on here but I'm past it now. I'm currently s…
Here it is, after a few months! The TJ-SR-v4 is the first sniper rifle (to my knowledge) to use the ball socket connectors as a bullet lock, greatly improving the range to a great 110 ft! The sniper includes:
Pros
110 ft range
Accurate
True trigger
Comfy
Easy to use
Cons
Single shot
Uses a lot of pieces (someone please do a piece count!)
The firing pin is sometimes a pain to pull back as it locks on to the ball connector.
Step 1: Handle and Trigger
One picture, it should be simple enough
Step 2: Body and Stock
You will need leather fingers to do this, but if you don't, just have a go, and use plenty of bandages.
Step 3: The Barrel and Foregrip
This is easy - it is 12 connectors long, and has the foregrip at the 5th connector from the bottom.
Step 4: Rubberbands, Loading and Firing
Read the instructions
1.(this is without the sight on) the rubberbands are stretched around the yellow connector and round the firing pin.
2.The trigger band goes where you see it.
3. Pull the firing pin back, slide the bullet in, holding it out slightly, and when it gets to the right place, push it down until it locks into place, then pull the trigger.
You may get even better range if you sharpen the end of the firing pin, but i can't be bothered to mutilate my pieces..
Any questions, just ask!
The Jamalam
