Introduction: TR8-2013 Last Updated 04/01/2014
04/01/2014 video TR8 overview and updates
08/31/2013 Step 7continued
08/29/2013 Step 8 Attachment Slide/Charging Handle
08/26/2013 Step 7 K'nex War 2013 inspired mods!!!
07/20/2013 DISCLAIMER! DO NOT AIM OR SHOOT THIS K'NEX GUN AT PEOPLE, ANIMALS, OR ANYTHING YOU DO NOT INTEND TO HIT. USE AT YOUR OWN RISK. This is my tested and K'nex WAR proven TR8-2013. If this gun which is built entirely out of K'nex is not built exactly as I have pictured IT WILL NOT PERFORM AS I CLAIM IT WILL. This gun was designed and built to shoot fin ammo. I will be showing both how to build the TR8-2013 and fin ammo. With both the gun and the ammo built exactly as pictured only then can I promise you similar results as I have obtained with this gun. As far as modding do as you wish but know that if your gun does not perform as good as I said it could consider that it is your mods that have tampered with the final results. I recommend that if you do attempt to build this gun you place each and every piece in place exactly as I have done so or please do not expect similar results. With all that political mumbo jumbo out of the way lets get to building!
Stats
the TR8 was designed and built around my fin ammo
over 4 years of development since first introduced in 2009
tested, retested, improved, and proved reliable and effective at 3 major K'nex WARS
auto rotating turret with ratchet for ease of use and rapid ROF
8 round turret capable of shooting any size rod including oodammo and fin ammo
capable of shooting fin ammo up to 300ft with 6 or 7 size #64 rubber bands
Step 1: Turret
16 Standard Metallic Blue Clip Connectors
3 Standard Tan Clip Connectors
40 Standard Light Gray Connectors
5 Standard White Connectors
Miscellaneous
2 Blue Spacers
2 Silver Spacers
Rods
32 Standard Green Rods-3/4in
8 Standard White Rods-1 5/16in
8 Standard Blue Rods-2 1/4in
1 Standard Black Rods-7 1/2in
1 size #64 rubber band
Step 2: "Block O K'nex" Barrel/Body/Grip/Trigger
9 Standard Black Rod/Connectors
4 Standard Metallic Blue Clip Connectors
2 Standard Tan Clip Connectors
2 Standard Dark Gray/Purple Connectors
3 Standard Orange Connectors
22 Standard Red Connectors
3 Standard Green Connectors
33 Standard Yellow Connectors
1 Standard Gold Connector
10 Standard White Connectors
Miscellaneous
1 Blue Spacer
1 Black Ball Socket
1 Black Hinge
Rods
30 Standard Green Rods-3/4in
2 Standard White Rods-1 5/16in
2 Standard Yellow Rods-3 7/16in
7 Standard Red Rods-5 1/8in
1 Standard Black Rod-7 1/2in
Step 3: Pistol Grip/Stock
4 Standard Black Rod/Connectors
3 Standard Light Gray Connectors
8 Standard Orange Connectors
8 Standard Red Connectors
7 Standard Green Connectors
53 Standard Yellow Connectors
2 Standard Blue Connectors
Miscellaneous
6 Blue Spacers
Rods
48 Standard Green Rods-3/4in
37 Standard White Rods-1 5/16in
6 Standard Blue Rods-2 1/4in
4 Standard Black Rods-7 1/2in
Wheels
6 Black Wheels-1in
6 Black Tires- 1 1/2in
Step 4: Firing Pin/Guide Rod
1 Standard Metallic Blue Clip Connector
1 Standard Dark Gray/Purple Connector
1 Standard Light Gray Connector
Miscellaneous
1 Black Ball Socket
Rods
2 Standard Black Rods-7 1/2in
electrical tape
scissors
Step 5: Final Assembly
Rods
1 size #64 rubber band on the charging connector
1-7 size #64 rubber bands on the firing pin
Step 6: Ammo
TR8-2013 accurate/max ranges
any size K'nex rod will accurately shoot 25ft max and 75ft total
oodammo will accurately shoot 50ft and have a max range of 75-100ft before they begin to break at impact of the firing pin. I highly recommend using a max of 5 size #64 rubber bands on the TR8-2013 with oodammo. Any more than that and they break before they ever leave the gun.
fin ammo will accurately shoot 100-125ft and have a max range of 300ft. They shoot straight and what you aim at will be hit. The key is knowing how much to "lob" the shot at ranges above 100ft. Any projectile in the world follows the rules of gravity however it is a matter of knowing how to aim the shot. I've hit targets at 200ft away with the TR8 it just takes some practice.
