Introduction: TV Stand
My parents had a tiny book shelf for their new TV so decided to build them a TV stand as a Christmas gift. The console took 3-4 weekends to build and cost around $200 in materials. The oak wood and light stain was chosen to match existing furniture. Dimensions: 65”w x 20”d x 27”h
Step 1: Cut ¾” Plywood for Top and Bottom
Step 2: Notch Corners to Fit Corner Posts With Edge to Meet Depth of 2x2 Corner Post
Step 3: Glue and Finish Nail Edge Pieces to Top and Bottom
Step 4: Reinforce Finished Edges to Top With Pocket Holes Using Kreg Jig
Step 5: Braces Added for Hex Bolt Support to Corners. Countersunk Hole for Corner Screw.
Step 6: Legs Attached With Bolt.
Step 7: Process Repeated for Bottom Shelf With 2” Gap for Clearance Under Stand (bottom Being Held Up by Support Pieces in Pic As I Screwed in Corners.
Step 8: Used Pocket Jig for Bottom Rather Than the Corner Bolts.
Aligning the corner bolts for the bottom was difficult so I opted for pocket screws instead.
Step 9: Top and Bottom Finished.
Step 10: Panels for Sides Measured, Cut and Secured With Pocket Jig Screws.
Step 11: Divider Panels Cut and Secured With Pocket Jig Screws.
Step 12: Slight Gap Left in Front to Allow for Oak Iron-on Veneer Facing.
Step 13: Center Shelves Measured and Secured With Pocket Screws.
Step 14: Support Brackets for the Shelves Cut and Screwed to Sides and Middle.
Step 15: Shelves, Drawer Fronts and Back Cut
Left and right shelves cut and edged with finishing trim. Drawer fronts measured and cut to size of the openings. I opted for 2 drawers at the bottom and left the top open for a cable box and/or dvd player. I cut 3/4" plywood to size to fit the back openings and opted to leave the drawer slots open in the back. Back was inserted using pocket holes.
