Introduction: Table
In this Instructibue I made a very basic table
You will need to get a screw gun, some screws, a tape measure, a saw, a pencil and a square to make this table
Step 1:
Make a plan on how to get you table to the best you can and measure all your pieces of wood to get the best result
Step 2:
Cut the wood to what length you need it and make sure it's all even on all sides even you can make your own measurements to what you want
Step 3:
Grab all you wood and put it on a table and grab some tools that will help you get it all together i used 1.5in screws if your table is wider you can use some longer one as long as you don't let the skrew blow to the leg
Step 4:
Start screwing all your pieces of wood were you want them and when your comfetible with the wood being flush
Step 5:
When you get all your peceases together strat sanding the table top and the legs to get rid of all the brurs and sharp edjeses and get it all smooth
Step 6:
When your done all that you should have the perfect table to hold stiff and you shouldn't have to worry about it breaking
