Introduction: How to Make a Table Pallet and PVC Pipe
In this instructable I will show you how I made this easy and simple table using one pallet and PVC pipe.
Step 1: Disassemble the Pallet
- First I disassemble the pallet (there is a lot of video on how to do this) then I chose the pieces I will use to build the top of the table
Step 2: Building the Top of the Table
1- I took two strips wood I put the them parallely.
2- I screw the frist wood strip on top of first two pieces.
3- I screw six other wood strips next to the first one to form the top of the table.
4- I cut off the excess wood from the first two pieces
5- I sand the top of the table using sand paper.
6- I put 2 layer of stain.
Step 3: Making Connectors for the Legs
1- I took to PVC connectors.
2- I cut off the parts where the PVC pipe goes. (see the pictures).
3- I measure 5cm from the end of the wood strip and 2cm form the side. (see the Pictures)2
3- Then I glue the connectors to the table using superglue.
Step 4: Making the Legs
1- I used 4m +10cm PVC pipe diameter 40, and 6 T connectors.
2- I cut the PVC pipe to :
1x93cm
2x61cm
2x 51cm
2x 41cm
2x5cm
3- I painted the pipes in black.
4- the 61cm pipes will be the front leg, I put them in the 2 first connectors
5- I put the 51cm pipes in the two last connectors.
6- I put two T connectors in the ends of 93cm pvc pipe then I connected it to the 51cm pipes.
7- I put the 5cm pipes in the T connectors.
8- I put the T connectors on the 41cm pipes then I connected them to the legs.
I hope this build is clear (sorry for my english), you can watch the video for more details.
thank youuu!
