Introduction: Table Saw Sledge Accuracy Test - Five Cut Method
About: Artist and maker.
I was sent a message by Andrew Goodrick, asking me why I didn't use the five cut method to align my table saw sledge.  Well I didn't know about the technique, and had originally used a square and my eye, which I was satisfied with.
Some of you may have noticed my original attempt to test whether the sledge cut square, using a charlatans version of the five cut technique, and the miraculous 0.02mm error, which in itself  was incorrect.  I guess I was surprised but considering I rushed to film the process, and forgotten half the procedure it is not surprising.
So I decided to re watch NG's detailed and instructive video about the correct procedure to measure the sledges accuracy.  The original video is linked here:  http://youtu.be/UbG-n--LFgQ which I really do recommend.
Subtracting the thickness measurement of the top by the bottom, of the slice created from the fifth cut, divided by 4 which is the amplification of error in rotating the piece around.  Then divided by the length of the cut and multiplied by the length of the fence gave me -0.4675mm, which is how off the fence is.
27.89 -- 29.25 = -1.36
-1.36 / 4= -0.34
-0.34 / 400 = -0.00085
-0.00085 * 550 = -0.4675 which is half a mm.
And because it is a negative number this means my fence is too low on the side I was cutting on.
Anyway this is just further reason why I should just buy a real table saw.
