Introduction: Table Tennis Score Board
This is a 3 buttons control table-tennis score board, 1st player, 2nd player and reset.
You will need :
X3 220ohm resistors
X3 Push Buttons
X1 Dual (8 digits) max7291 7-segment display
an Arduino, the diagram shows UNO but i only used it at the planning level, afterword i changed to pro-Micro
Some Cables.
Step 1: It Is Simple
The program increase each player score every time the player button is pushed.
if eather of the player reached 11 points and the score differents is bigger then 2 then the game counter is increased and a new match begins.
Step 2: Code....
#define MAX7219_DIN 5
#define MAX7219_CS 6 #define MAX7219_CLK 7
#define leftB 8 #define rightB 9 #define RESETb 10
int left, right, rightPlay, leftPlay = 0; boolean changeIndc = false; int SRead;
void initialise()
digitalWrite(MAX7219_CS, HIGH);
pinMode(MAX7219_DIN, OUTPUT);
pinMode(MAX7219_CS, OUTPUT);
pinMode(MAX7219_CLK, OUTPUT);
}void output(byte address, byte data)
digitalWrite(MAX7219_CS, LOW);
shiftOut(MAX7219_DIN, MAX7219_CLK, MSBFIRST, address);
shiftOut(MAX7219_DIN, MAX7219_CLK, MSBFIRST, data);
}void setup() {
Serial.begin (9600);
pinMode (leftB, INPUT);
pinMode (rightB, INPUT);
// put your setup code here, to run once:
initialise();
output(0x0f, 0x00); //display test register - test mode off
output(0x0c, 0x01); //shutdown register - normal operation
output(0x0b, 0x07); //scan limit register - display digits 0 thru 7
output(0x0a, 0x0f); //intensity register - max brightness
output(0x09, 0xff); //decode mode register - CodeB decode all digits
output(0x08, 0x00); //digit 7 (leftmost digit) data
output(0x07, 0x0a);
output(0x06, 0x00);
output(0x05, 0x00);
output(0x04, 0x00);
output(0x03, 0x00);
output(0x02, 0x0a);
output(0x01, 0x00); //digit 0 (rightmost digit) data}
void loop() {
SRead = Serial.read ();
if (SRead ==48 || digitalRead (RESETb)) {
Serial.println ("RESET");
left = 0;
right = 0;
leftPlay = 0;
rightPlay = 0;
changeIndc = true;
output (0x01, 0);
output (0x08, 0);
if (SRead == 49 || digitalRead (leftB)) {
delay (200);
while (digitalRead (leftB)) {}
left++;
changeIndc = true;
if (SRead == 50 || digitalRead (rightB)) {
delay (200);
while (digitalRead (rightB)) {}
right++;
changeIndc = true;
if (changeIndc) {
output(0x03, left % 10);
output(0x04, left / 10);
output(0x05, right % 10);
output(0x06, right / 10);
if (right >=11 && right >= left +2) {
rightPlay ++;
right = 0;
left = 0;
output (0x08, rightPlay);
if (left >=11 && left >= right + 2) {
leftPlay ++;
right = 0;
left = 0;
output (0x01, leftPlay);
changeIndc = false;
