Introduction: 123D Design Table, Chair With Glass and Bottle
This123D Design project is a project that ties in the elements of design and sheer creativity to make a table with chairs, glasses and a bottle.
Step 1: Step 1: Build the Table
The base, which is a circular cage, can be made by adding in a spline or a line. This line cane be modified by adding a circle at the bottom to measure the thickness of the column.
Step 2: Step 2: Finishing Base and Table Top
Once this column is complete, you must use the circular pattern to make the intertwining looking shape. Once you are done with this. draw a circle on the ground. Extrude this and fillet the edges according to your needs. Scale it and snap it to the base.
Step 3: Step 3: Bottle
Use multiple polygons such as cylinders and hemispheres to start the bottle and cup. For the bottle stack a hemisphere on a cylinder and build a smaller cylinder on top. Use snapping tools to help the aligning of the polygons. Once this is done you can select the material of glass.
Step 4: Step 4: Cups
For this you may need a variety of polygons. Choose a hemisphere and adjust its size. Then you must shell this so that is looks more like a base. Add a cylinder and scale the size to 1 or 1.5 so that it appears as the long connector for the base and the actual cup. This cup can be built by stacking an upside down hemisphere with a cylinder and shelling it. Snap all together and done with cups.
Step 5: Step 5: the Chairs
To start the futuristic chairs, you must draw a spline in a squiggly line. Then extrude this and turn it 90 degrees. Using the tool of splines, apply a line that makes up a U shape, place a circle at the bottom of it and sweep it up to create a small shape that resembles a metal bar. Snap this bar to the already created base of the chair to finish up the chair.
Step 6: Step 6: Finishing Up
When all parts are completed, place the bottle and the glass on top of it. Copy paste the glass to create two glasses. Place the chairs close to the table and copy paste this. Once completed, place the other chair adjacent to the other chair. Now you have completed the authentic table with chairs, glasses and bottle.
