Introduction: Taco Charm
This rainbow loom charm is a really good charm to put on your bracelet it is also a really easy charm to make,I will be posting more charms to do with food!
Step 1: Step 1: Getting the Right Amount of Bands
you will need 37 rubber bands altogether ,any type of loom and a hook to make this wonderful taco charm
Step 2: Step 2: Starting the Taco Charm
starting on the first peg to the right go up with on band then with two bands go diagonally up like it shows you in the picture.
Next go up taking two different colour bands first go up with the two different colour bands mine are green and red, then take two other bands of the same colour mine are green again and go up one then continue the pattern until you get to the point where the picture is at.
Step 3: Step 3: Finishing the Layout
next go back to the bottom and with the colour you are doing for the taco shell go up and stop at the place where the picture stops at.
Now on the left side carry on the pattern diagonally up one like the picture and then go up one diagonally again with the orange which is the meat.
Then just put a cap band on the end like is shown
Step 4: Step 4: Now the Hooking Process
next using one band for each triangle starting at the bottom go up with the colour you are using for the taco shell.
Now starting with the hooking process turn your loom around and from the cap band start hooking. Take the top two bands first and gradually go all the way down and stop where the pictures stop.
Step 5: Step 5: the Simple Slip Knot
for those who do not know how to do a slip knot take the bottom band and pull it over the top of the other band then pull the othe band and that is your simple slip knot like shown in picture.
Step 6: Step 6: Pulling the Taco of the Loom
the easiest part is pulling the taco charm of the loom, carefully starting and the end where you started hooking from pull the taco off the loom.
Step 7: Step 7: the Final Touches
your taco charm should look like this but do not worry pull the part that should be in the middle in the middle until it stays.
Step 8: Step 8: Finish
you're taco charm should look like this on the front and on the back
Hope you liked making this taco charm be free to tell me if you got confused on a step and I will make it more simple also you can look at all my other designs I am sure you will enjoy making them.please follow me as I am going to be posting lots more designs.
Bye see you next time!
