Introduction: Tactical Multitool
When camping, I often wish I had brought a tool along; a hammer, a hatchet, a shovel, etc. Especially on backpacking trips, however, the weight and hassle of carrying 3 or 4 tools is over the top and not worth it in the long run. The Tactical Multitool is the perfect solution. It combines the versatility of a tool shop with the simplicity of any other camping gadget. It especially stands out in its ability to mismatch a number of "heads" in many combinations. The ability to detach, reattach, and swap "heads" makes this a truly unique tool.
Whether you're camping in the wilderness or fixing something around the house, there's always the right tool for the job. So, while you read the process I took to make this Tactical Multitool, let your creativity run free and help me think of more ideas to add to this "one-tool toolbox". The possibilities are endless!
Step 1: Materials
Materials:
1/8" Cold Rolled Steel
1/8" ABS Sheet
5/16" Steel Rod
Steel Wire (16-14) Gauge
Epoxy or Super Glue
Black Paint
Tools:
Welder
Bandsaw (or some other saw capable of cutting 1/8" steel)
Drill Press
Milling Machine
Angle Grinder
Clamps
Pliers
Step 2: Design
The basic design of the Tactical Multitool consists of a central "frame" piece shaped like a "T". It is built of two identical pieces that sandwich a small "spacer" piece at the "T" junction. This creates a space between the two frame pieces and a slot into which the several "heads" can be inserted and affixed. These heads are affixed using what I referred to as an "attachment unit", which consists of two pins connected by a backplate. The pins go through the first "T", through the head, through the second "T". The attachment unit is held in place by a cotter pin which keeps the pins from sliding out of the frame. (See Step 7 for clarification)
**Originally, the heads had "B" pieces that were designed to be welded to the attachment to increase strength and stability. The 1/8" steel, however, was much stronger and more stable than expected and therefore the reinforcing "B" pieces were no longer needed (See pictures for clarity).
Step 3: Cutting the Frame
The "Frame" consists of the two "T" pieces and the "spacer". These pieces were cut out of the 1/8" steel sheet with a bandsaw. With the spacer sandwiched between the two "T"s, the slot is formed where the heads will be attached. The gap in the handle area will be filled by the 1/8" ABS sheet in a later step.
Step 4: Welding!
Once the two "T" pieces and "spacer" piece are cut, the spacer must be welded to one of the "T"s. I am very far from having mastered the art of welding, but after a bit of practice my welds were at least functional. One the spacer is welded, all three pieces must be welded together with two beads along both sides. See pictures for clarity.
Once the welds are finished, they should be ground flat with the angle grinder. Be careful when welding or using the angle grinder on metal; things become very hot very quickly. Don't burn yourself like i did! Once everything is welded together, the holes for the "attachment units" must be drilled. These holes must match the 5/16" diameter of the pins and must be perfectly straight. That is why a drill press or mill is necessary for this step.
Step 5: Cutting the "Heads"
The heads were cut from the 1/8" steel with a bandsaw. Rough edges were smoothed with the angle grinder. Three potential heads are shown below: the tomahawk/hatchet, the backspike, and the hammer. A quarter-circle is cut out of the corner of each head to match the semicircular section of the "spacer" piece. Both the backspike and tomahawk/hatchet heads can be sharpened. This was done with an angle grinder, however, i decided to leave the backspike dull.
In order to make sure that the holes drilled in the heads matched the frame perfectly, the heads were clamped into the frame and the frame's holes were used as a guide to drill into the heads. All burrs left from drilling must be removed with sandpaper or a hand file or else the pieces will not fit together.
Step 6: The Handle
In order to remove weight from the frame, channels were milled along the handle. The large holes drilled at the top and bottom of the handle allow for the Multitool to be fastened to a backpack or clipped to a belt. Once the handle was milled out, the gap caused by "spacer" piece was filled by the 1/8" ABS sheet. This panel was glued between the two metal handle pieces and clamped down to dry. Once dry, the leftover ABS was removed from the handle.
Step 7: Attachment Mechanism
The Attachment Mechanism consists of three parts: the pins, the backplate, and the cotter pins. The pins are 5/16" diameter steel rods cut into 3/4" pieces. Four are needed. Two rods will be welded to each backplate (made of 1/8" thick steel), creating an attachment unit that will hold a "head" in place. The welds were done with the pins in the frame in order to assure that the they were welded straight. Once welded, the backplate-pin unit was inserted into place and holes were drilled in the pins to allow for the insertion of the cotter pin. See pictures for clarity.
The cotter pins were then formed by inserting the steel wire through the two holes and then bending it back on itself. After a few additional twists and turns with a pair of pliers, the final shape was achieved. See pictures for clarity.
Step 8: Finishing Touches
The holes in the frame and "head" pieces may require some extra drilling to make sure they are matched up perfectly. Once this is done, the tool can be left as is or painted, as shown below. I used a primer layer of automotive paint and then finished with a textured black spray paint. I am very satisfied with the final product!
Before painting you may want to use an angle grinder to grind the edges of the handle. This will provide a smooth edge when gripping the multitool. You can also fashion your own grip from paracord or some other material.
After a good amount of use, the adhesive holding the handle together broke. Another solution was necessary to keep the handle together permanently. In order to do this I welded a small piece of 1/4" steel rod to the bottom of the handle, thereby connecting the two frame pieces.
Step 9: In Action
Now its time to use your Tactical Multitool! I did a couple of pre-paint tests on the finished product. The backspike held up well against the railroad tie (see picture) and the Tomahawk attachment works like a charm! (see video)
As always, be safe while using this tool because it can cause harm or serious injury. But most importantly, have fun!
I would love to hear any ideas for new attachments so that I can expand the scope and capabilities of the Tactical Multitool!
Finalist in the
Metal Challenge
Make It Real Challenge
43 Comments
8 years ago on Introduction
It is kind of hard to tell what "heads" you have at the moment, so I'm just going to post a comprehensive list from what I've seen, and what others have suggested, and my own ideas of course.
Axe/hatchet
Spike
hammer
pickaxe
crowbar
spear head
machete/blade
forked head (perfect for stoking a fire or cooking wienies over a fire)
shovel
chisel
scythe
hoe
ladle or bowl to carry liquids?
saw
you could also add something so you could add a slingshot head or something
add a curved hook (like a grappling hook head) for climbing and grabbing trees
ice pick (for climbing and procuring ice)
a head that works like an adle-adle so you can throw spears crazy far
add instead of a head a metal square that has a chain bolted to it, then a spike ball on the end to make a flail
that's about all I can think of. Great work on your project!
i agree with those that have said for a pickaxe attachment, also how about a machete type blade attachment to cut things such as tall grass or vines in your way, could attach like the shovel, hoe attachment for the farmer type, sickle attachment also for the farmer type, crowbar maybe for opening or moving things, these would be great as attachments in my own opinion
I have to say that this is a very very impressive build. The design is ingenious and would save tons of weight if you used it. The interchangeable heads are really cool. I'd love to make one, but ... I don't have means to weld. Anyways a spearhead attachment would be pretty neat if you made one.
9 years ago on Introduction
also I'm suggesting a pickaxe add on
what is its exact weight
what are the dimensions - especially for the handle
9 years ago
Pretty cool I would like to do this When I get older
9 years ago
great work bro. ill have to build one one day.
10 years ago on Step 7
Have you thought about welding rings onto the backs of your attachment mechanisms? attaching those to the frame to keep them from being dropped could save you a lot of work replacing them later
10 years ago on Introduction
Excellent work, 5* and favorited, but I'd ditch the back spike. I've never, and will never, understand the reasoning behind a back spike on a tomahawk. Why in the name of all that is holy would you want a sharpened piece of metal pointing right at your face? If you're chopping would and it rebounds, BAM! Left eye gone. If you're using it in a combat situation, and you lose control for a nanosecond, BAM! Nice new hole in your chest.
Sigh. Humans. Sometimes I doubt we are truly the smartest things on the planet.
I would have turned the bottom edge (From the Middle to the Head) into a SAW EDGE so you can control the cut and it should be lighter work because of the weight of the 'Multi-tool'
10 years ago on Step 9
You could attach an anchor point at the base of the handle and a new attachment for the head and run a chainsaw chain in between them.
11 years ago on Introduction
Very well done, indeed. Keep it up.
Great Job! I would recommend making the angles in the Tee section curved, because of stress concentration. This should help reduce the risk of cracking.
and just FYI tools (such as hammers) are made from tough material, so they wont chip (i.e., dangerous flying pieces of metal) and are surface hardened to reduce wear. Also, I don't know how the material will behave after welding too.
very well executed, but I just can't understand what you need a backspike for? at least, not for practical usage (unless you hunt bears with it) ;) Overall, it sems to be a very sturdy multitool-thingy
For your average innovative type, this is REALLY good! For a highschool student? (*&&^)(*P Brilliant!!! Outstanding job! with a little refinement this could be a marketable product. Really outstanding. Hope to see more from you.
Outstanding, thank you very much! A lot of us think about this and even attempt it, you did well!
11 years ago on Step 2
I love it, I think I will try making one too. Just for something to go by, what are the approximate measurements for the handle and head attachment area?
11 years ago on Step 9
As long as you have such a flat handle, why not make it a flat bar for pulling nails and prying? Also suggest a saw attachment head.
Tool addition: spade head that attaches to both attachment points at once.
Also, make sure the hole at the bottom is sized right for pulling tent stakes. That's the only thing that crappy plastic stake mallets are good for.
