Introduction: Tactical Shotbow
I like oodammo, I wanted to make a new knex gun, and I have heard alot about S0lekill3r's shotbow. So I made a shotbow. This shotbow is much more compact than sS0lekill3r's, and functions just as well. I decided to put my dot sight I made a few weeks ago on it, and also to have a comfy forgrip. I have not discovered how to put on the rubberbands in a one pull=2 shots configuration, so this is always a shotgun. Hope you like it!
Credit to S0lekill3r for the mag, and that's it!
If you build one, please show me, I'll add it to the ible.
Pictures of any mods wanted.
Pro's
-compact
-has tactical rail on top
-forgrip
-exellent trigger
-10-round mags
-accurate
-high ROF
-looks sick
-100% reliable. It has never failed me in the 100's of times I have fired it.
Con's
-very slow mag reload
-uses lots of white connectors
-can't really put into a semi-auto mode.
Lets get building! Don't forget to rate and comment!
Pro's
-compact
-forgrip
-exellent trigger
-10-round mags
-accurate
-high ROF
-looks sick
Con's
Step 1: Main Body
Okay, this is where the magic happens. Very simple, I start with the middle layer.
Step 2: Handle
This is the handle and beginning of the stock. Very easy.
Step 3: Trigger
This is a quik and easy step. Follow the image notes.
Step 4: Stock
This is the stock. Make it.
Step 5: Final Touches and Assembly
Yay! Were're almost done! Just a few things more!
How to fire: You pull back the puller thingy untill the ramrods lock, then push it all the way forward. Pull the trigger. Repeat 10 times.
I can get a really high rate of fire going, the puller thing makes your life alot easier.
Step 6: Fun Pictures and Your Tactical Shotbows.
If you build your own Tactical Shotbow, show me! I'll add it in this step.
I took some pictures of the oodammo in mid-air. It is really cool, but fuzzy.
