Introduction: Taiwan Guide Map (Arduino)
Taiwan, the country that I live in for 15 years. Therefore, I decided to make an impressive device to commemorate my country. The device I gonna represent is 4 LEDs lights with switches and 4 intros about Taiwan. The making process won't be difficult, but it will repeat similar steps over and over again. Although it will cause you to do a similar step for many times, but it is quite simple and easy for everyone.
Step 1: Step 1: Prepare the Materials
- One Arduino Leonardo
- Breadboard
- Generic jumper wires
- 220-ohm resistor x3 and 330-ohm resistor x3
- x3 LEDs with different color
- x3 switches
- x1 carton box
- x1 Utility knife
Step 2: Step 2: Making Exterior of the Device
- Cut the carton into two pieces
- One for making the box to cover the breadboard, another for making Taiwan map
- After finish making Taiwan map divided it into North region, Central region, South region
- Drilled a small hole ( that can just right size with the LED lights ) in every region
Step 3: Step 3: Create the Circuit
Copy the code: https://create.arduino.cc/editor/stanleylee/e1fee4...
- Use 4 generic jumper wires respectively connect to Pin 2, Pin 6, 5V, GND, and also take an LED, a switch installed in the breadboard
- Take another wire installed in switch anode, the wire connections with Pin 2 installed the switch's cathode
- Connect the resistor next to the switch
- Use the wire, which connects with Pin 6, connects with LED light
- Connect the LED with the resistor
- Take a wire to connect with the resistor's cathode and cathode
- Repeat those simple steps another 2 times
