Introduction: Take Apart an Old Laptop and Recover Usable Parts
This is an very old laptop from IBM, Model 570 with an Ultra Base. There is a major problem with the laptop and it fails to boot. The cost of repairing is very high, so we left it as it is. As it is lying unused, I thought of taking apart the laptop and recover usable parts from it.
Step 1: Tools and Accessories
I have used the following tools and accessories for opening the laptop and removing parts
- A Screw Driver set suitable for computer repair
- A pair of Tweezers
- A Multi-meter
Step 2: Remove Battery
- Make sure that the laptop power adaptor is not connected.
- Open up the battery compartment and remove the battery
- The battery is made up of individual cells. I have tested each of them separately and found them useless
- These cells will be disposed off safely
Step 3: Open Top Cover and Remove Key Board
- Remove screws holding the top cover
- The keyboard is connected to the motherboard with a ribbon connector
- Pullout the ribbon connector and remove keyboard
Step 4: Remove LCD Screen
- Remove the screws holding the LCD Monitor
- Detach the ribbon cable connecting the monitor with motherboard and remove it
Step 5: Recover LCD Panel
- Open up the frame holding the LCD panel and gently detach it from other circuit boards below and remove the panel
- Hold it gently and do not touch the edges and note down the model. It is LP121SP
Step 6: Remove Hard Disk
- Remove screws holding the hard disk and pull out
Step 7: Recover DVD / CD Drive and Floppy Drive
- There are few screws holding the DVD / CD drive with the frame. Unscrew them and pull out the drives
Step 8: Locate Other Parts
- Now the motherboard is exposed and you can locate other recoverable parts
- Memory module, Lithium cell, Cooling fan, Built-in modem, Network Adaptor and Sound Card can be located easily on the motherboard
Step 9: Remove Memory Module
- There are plastic clips holding the memory module
- Press the clips outward and the memory module will pop out from its position
Step 10: Remove Other Parts
- Unscrew the screws holding the built-in modem, detach the ribbon cable and remove it
- Remove screws holding Sound card and pull out the ribbon cable
- Unscrew the Network card and remove it from the frame
Step 11: Recover Cooling Fan and Lithium Cell
- Detach the cable powering the cooling fan and remove it
- Unscrew the holder and Pull out the Lithium cell
Step 12: Keep Recovered Parts Safely
I have recovered all the removable parts from the laptop and packed them safely in a card board box. If I need the parts in any of my future projects, I can use it from the collection
